Author Topic: Yaesu FT1000D no Audio issue  (Read 345 times)
K9NRA
« on: November 24, 2017, 09:29:08 AM »
Went to use my FT1000D after it being off and unhooked for approx. 3 weeks, now I have no audio out of internal speaker or external speaker. Can hear the tone from SPOT button and band changes just fine, no problems with receive signals on several bands, just no receive audio out. Squelch is set to min, AGC to fast or slow doesn't affect the lack of sound. Any thoughts?
KB1MIQ
« Reply #1 on: November 25, 2017, 09:33:18 AM »
I won't be much help, but I'll give it a shot.  Look at the external speaker jack and the head phone jack.  If they have a problem, they can cut off the audio.  Also, though it's less likely, look around for a potential short that could cause the audio board to think there is a speaker or phone set plugged it.  If you have one of those fancy table top mics, check to see if there is a mute circuit on it.    Double check your front panel switches to be sure the radio is in the correct receive line up.  Sorry, best I can do.  Don't know your rig, just covet it !  Good luck...
