Author Topic: ARRL staff have released TQSL "Configuration Data" version 11.3  (Read 696 times)
AA6YQ
« on: November 24, 2017, 04:36:15 PM »
This update contains this addition made since the release of "Configuration Data" version 11.2:
- in the Satellite enumeration, added an entry for AO-91 AMSAT-OSCAR 91 (RadFxSat / Fox-1B)
If you are using the current version of TQSL, you will be prompted to update your "Configuration Data" the next you start TQSL. You can also open TQSL's Help menu and select the "Check for Updates" command.
For more information, see
https://lotw.arrl.org/lotw-help/configxml/
N5VYS
« Reply #1 on: November 24, 2017, 05:29:16 PM »
Updated earlier.
Obie
« Reply #2 on: November 24, 2017, 05:32:54 PM »
That was quick and easy. A few more clicks got a certificate renewal request submitted.
