Author Topic: SO-50 satellite question  (Read 697 times)
KU4UV
« on: November 27, 2017, 07:28:13 AM »
I tried to work SO-50 early this morning around 6:00 local time here in Kentucky during an 89 degree pass.  I didn't hear any stations from the satellite.  This is odd, as I heard stations last night during the pass.  Any thoughts on why sometimes the satellite appears to "asleep,"  and sometimes it is active?
KU4UV
K6LCS
« Reply #1 on: November 27, 2017, 07:38:48 AM »
It was possible that no one else was attempting to work it during that pass. Did you send it a 74.4 CTCSS tone to activate it, then try to work it?
Clint Bradford, K6LCS
http://www.work-sat.com
KJ4HVL
« Reply #2 on: November 27, 2017, 11:04:54 AM »
Greetings to another Kentuckian! As a ground station OP at MSU, we found that some satellites would sleep during their eclipse phase (power saving when dark)... Additionally some GMSK modes are wider than the FM voice passband. You will hear your radio squelch open, but can't get into or out of the bird when they are downlinking data.
Other times when the earth appears "hot" (lots of ham activity) the satellite rx will de-sense and it can be hard to get into them without a whole lot of gain.
Additionally geomagnetic activity can play a role. Sometimes especially when the bird is north of KY the aurora can block signals.
I don't know if any of those are the case.
KU4UV
« Reply #3 on: November 27, 2017, 12:23:13 PM »
Yes, I thought about that.  I tried to "wake" the satellite by sending my call and grid when I transmitted.  Still didn't get any reply.
Ku4UV
KU4UV
« Reply #4 on: November 27, 2017, 12:26:05 PM »
Hello from Richmond.  I graduated from EKU with a degree in Broadcasting back in 1997.  This morning, SO-50 came down from the North, over Alaska and Canada, so that may be the case.  Thanks!
Mike KU4UV
