Author Topic: IC-7000/Signalink  (Read 605 times)
WA9ETW
« on: November 28, 2017, 02:12:06 PM »
Could I ask those of you using a Signalink USB with your IC-7000 to weigh in on the 6-pin vs. 13-pin question?  (I am already aware of the mic muting issue.)
Mark -- WA9ETW
W1JTO
« Reply #1 on: November 29, 2017, 04:52:30 AM »
6 pin all the way. 13 pin I heard has issues. Plug and play - works perfectly.
Get the optional jumper pre config.best 5 bucks ever spent.
Follow install docs precisely and slowly
John
W1JTO
« Reply #2 on: November 29, 2017, 05:56:50 AM »
I should add I just set my 7000 up this way
I also used a rtsystems usb cable for wsjtx civ control of split operation
ND6M
« Reply #3 on: November 29, 2017, 07:10:39 AM »
The 6 pin is the new industry accepted "standard", however, the ICOM 13 pin has a FIXED output level  , the 6 pin mini does not.
WA9ETW
« Reply #4 on: November 29, 2017, 02:48:46 PM »
I have also heard of extremely sensitive input level issues with the 6-pin configuration, and RF feedback issues (presumably something that could be solved with appropriately applied ferrites) with the 13-pin configuration.
Thanks for observations, guys.
Mark -- WA9ETW
WA9ETW
« Reply #5 on: December 06, 2017, 11:15:36 AM »
Dumb question but, if you're not otherwise using computer control (HRD, etc.), is a CAT/CIV cable also required to maximize the use of WSJT-X features?
Tnx,
Mark -- WA9ETW
ND6M
« Reply #6 on: December 06, 2017, 12:04:25 PM »
Tnx,
Mark -- WA9ETW
kinda depends on what you mean by "maximize".
 In a word,.................. No Wink.
I'm sure certain "experts" will differ
WA9ETW
« Reply #7 on: December 06, 2017, 12:41:39 PM »
Well, you're right; the word is subject to "interpretation."   Smiley I should have phrased it better, something along the lines of: Does WSJT-X require the use of a CAT/CIV cable for full functionality?
W1JTO
« Reply #8 on: December 06, 2017, 04:59:57 PM »
Mostly needed to move between bands.  if you just stay on 40m ... not really.
make sure your civ addr is 70H on the 7000
73 john
