Author Topic: TS-850 issue ON 14 MhZ only  (Read 240 times)
W2TB
« on: November 29, 2017, 07:50:52 AM »
Hello all:
When I switch to 14 mHz, the audio is raspy and wide on both SSB and CW. When I switch to the other bands, no problem. I set the VCO1 to 5 volts at TP1, and double checked it. This is strictly on 14 megs. What gives? What should I look for? A cap on the carrier board? BTW they were all swapped out and I have the newer DDS chips and a late serial number radio. Who can help?
Thanks.
Mike W2TB
