Author Topic: FT-8  (Read 1577 times)
W3BJ
« on: December 04, 2017, 10:18:23 AM »
anyone know how to set up TS990sat to WJSTx software. I load it on computer, all it does is just sit there. Copies nothing. gone thru setup mode, box comes up setup not right. tried a hundred times.
KK7JS
« Reply #1 on: December 04, 2017, 10:51:56 AM »
Could you describe your setup in a little more detail? What kind of connection do you have between your TS990 and PC? Is there any other ham software you typically use with it?
I have a TS990 and use HRD. I recently installed WSJT-x and used the HRD configuration option and had it working in short order.
« Last Edit: December 04, 2017, 10:54:09 AM by KK7JS » Logged
« Reply #2 on: December 04, 2017, 12:36:46 PM »
If you can't figure it out, you can email me and I will give you my phone number and we can talk on the phone and use teamviewer 12 so i can look at your PC, and we can get it going.  I have helped dozens of guys get set up.  Try yourself, but if you get frustrated, and can't make any progress, contact me.
James K0UA
KJ3N
« Reply #3 on: December 04, 2017, 04:56:17 PM »
Did you install time sync software like the manual (you have read the manual, right?) tells you in section 3?
W3BJ
« Reply #4 on: December 04, 2017, 05:35:06 PM »
Yes I installed time software. I have usb cable from USB port in rear of 990 to laptop win 7. I do not use HRD . It keeps telling me my setup confoguration is wrong. I dont know what to paramenters to use everything I use is faulted. My question is what databits, speed,   mainly the setup screen.
WW7KE
« Reply #5 on: December 04, 2017, 05:38:10 PM »
Check the manual for your rig first.  It may have the serial protocol fixed at a certain baud rate, parity, etc.
He speaks fluent PSK31...  One QSO with him earns you 5BDXCC...  His Wouff Hong has two Wouffs... Hiram Percy Maxim called HIM "The Old Man..."  He is... The Most Interesting Ham In The World!
W8VVE
« Reply #6 on: December 04, 2017, 06:14:39 PM »
Did you download & install Kenwood's virtual com port driver?   Sam W8VVE
W3BJ
« Reply #7 on: December 05, 2017, 05:02:44 AM »
I keep getting errror message: do you want to re-configure transeiver settings. I dont know what to change or where to set it. I can hear the ft8 signals fine, the wsjt program just doesnt put them on the screen I am sure its just a keystroke
AA2UK
« Reply #8 on: December 05, 2017, 05:57:56 AM »
Do you have this document?
http://www.kenwood.com/i/products/info/amateur/ts_990/pdf/ts990_usb_audio_manual_e_rev1.pdf
Bill, AA2UK
« Last Edit: December 05, 2017, 06:01:40 AM by AA2UK » Logged
« Reply #9 on: December 05, 2017, 02:31:17 PM »
We got him going..
W3BJ
« Reply #10 on: December 05, 2017, 05:26:16 PM »
SUCCESS.  TAKES A LITTLE TWEEKING
KK7JS
« Reply #11 on: December 05, 2017, 06:12:45 PM »
Glad to hear, and hope to hear you on the air.
W3BJ
« Reply #12 on: December 10, 2017, 01:50:05 PM »
My WSJT program now shows me error message: hamlib: program times out while trying to communicate with rig.  I didnt change anything   was working fine.  Kenwood ts990 with wsjyx programs usb cable to win 7 laptop   John
AA2UK
« Reply #13 on: December 10, 2017, 06:34:09 PM »
Have you by chance hit the config tab in the main WSJT X Window?
Try a restart of the rig and the computer.
Bill, AA2UK
NN2X
« Reply #14 on: December 11, 2017, 05:14:44 AM »
I used HRD, and then installed WJSTx software
HRD folks worked with me to set up...Nice feature from  WJSTx software it connects directly to the HRD software.
HRD, works directly into the USB, with one cable (Both signalling and control)...
Nice and clean...
I like this set up, as I can jump to PSK 31, or the magic mode Olivia using HRD, and then FT8 with WJSTx software. All seamless and only one cable to the rig (Via USB)
Also, if you have trouble, with HRD the help desk is awesome..
C U on the bands,
NN2X,
TOM
