Author Topic: TPL Amplifier VHF Transistor  (Read 497 times)
AD7C
« on: December 05, 2017, 05:30:40 PM »
I am trying to identify a transistor used in a TPL VHF amplifier.  I have a couple of these but this model was a very early production run and even TPL has zero info on it.  The transistors are marked "185 798-3 412".  I suspect TRW but I have no clue.
The amp is a TPL VHF P100-3 (or 1002-3) depending upon the label. 10w in and 120w out class C.
Rich
AD7C
K6AER
« Reply #1 on: December 08, 2017, 06:25:03 PM »
MRF-240 will work fine in the application. You need to replace all three. These are 40 watt devices.
AD7C
« Reply #2 on: Yesterday at 07:33:53 AM »
I don't think I need to replace all 3.  I lifted the tabs on all the transistors and checked them.  Only the single, driver transistor at the bottom showed bad when tested using the diode function on my DMM.  I suspect an input overload killed it and the others are fine.
However, thanks for the replacement suggestion!  I
Rich
AD7C
K6AER
« Reply #3 on: Yesterday at 10:35:05 AM »
Then just replace the driver. It is also a 40 watt device.
