Author Topic: Want yagi suggestions for sat work  (Read 1836 times)
WB1AAT
« on: October 23, 2008, 01:23:01 PM »
I'm looking to move up to 70cm/2M combo yagis after my stint with various omnis (turnstiles, moxons, verticals). I have an Elk and Arrow I use for handheld (they work well) but am seeking something a little better suited to being outside full time.
I've seen so far on the market:
mfj-1728
cushcraft A270-6S and A270-10S
hygain DB2345
Any opnions/experience with these? Yes I know I can use separate antennas and I know I can home brew. Dont want at this point.
Mike WB1AAT
KB9CRY
« Reply #1 on: October 24, 2008, 12:47:29 PM »
I use M2 antennas.
K6LCS
« Reply #2 on: November 05, 2008, 06:37:34 PM »
I thoroughly cleaned all parts of my Cushcraft Yagi before assembly, then sprayed marine spar varnish on it after assembly - for protection of/from the elements (pun intended). Cushcraft units are excellent.
Are you just thinking of base antennas for the FM birds???
Clint Bradford, K6LCS
909-241-7666
http://www.work-sat.com
WB1AAT
« Reply #3 on: November 05, 2008, 06:53:55 PM »
The FM birds yes. But also the SSB LEOs like VO52 and FO29.
Right now I have my Elk dual band log periodic on a tripod in the back yard at 45 degree elevation fixed and an ancient U100 rotor (love those old U100s). A dramatic imrovement over my omnis and just as good as my Arrow (without getting wet or cold).
I'm looking for something with a little more punch, hence my post.  Thanks for the suggestion of the Cushcraft.  Do you have the dual band A270-6S or A270-10S  ?
KA4NMA
« Reply #4 on: November 22, 2017, 10:45:05 PM »
mfj-1728
hygain DB2345
Mike WB1AAT
I found this post doing a search.  Mike, if you have any of the Omni antenna's laying around as surplus, I would be interested in getting them.  drop me an email pastor.spaceboy@gmail.com
Randy ka4nma
