eHam Forums => Computers And Software => Topic started by: N1KTJ on March 09, 2016, 07:08:08 AM
Title: One USB to rule them all
Post by: N1KTJ on March 09, 2016, 07:08:08 AM
I am thinking of getting a powered USB hub that I can connect to my computer over the maximum distance allowed for USB.  The powered USB hub would connect to a Signalink and a TNC-X and a CAT control for my radios.  Will need to look at SIGNALINK and consider its limits for distance and USB HUB use.
What issues can I have?  Do I want at least USB 2.0?  Or will I be better served by going with USB 3.0 and any suggestions for an adapter?
for low speed USB devices the limit is 9 feet while high speed its 15 feet.  That would cover the run from the USB hub back to the computer I suppose.
Title: RE: One USB to rule them all
Post by: KD8MJR on March 09, 2016, 10:30:55 AM
If you want any kind of real speed then USB3 is needed.  For a signalink and TNC-X a USB 2 connection is just fine, they both require very little speed and BW.
If your worried about distance just get USB Active repeater cables or booster boxes.
Here is one such item
http://www.amazon.com/Tripp-Lite-Hi-Speed-Extension-U026-20M/dp/B006KSLF6E/
73s
Rob
Post by: W8JX on March 09, 2016, 01:03:18 PM
You need to understand that only ONE device can talk at a time on a USB port/hub. It is time sharing. Timing critical device should be on a separate port from PC. Typically a PC or laptop with have a few USB hubs internally meaning that not all port are hooked to same root hub and as  long as devices are on different root hubs they can operate at same time. Devices like mice, keyboards, scanners and even printers are not timing critical and can share a hub without issues
Post by: K5TED on March 11, 2016, 08:39:45 PM
Interesting.. I'd be curious to know which ham radio transceiver uses USB 3.0 or can benefit from the use thereof.
I have:
1 USB SoundBlaster Audigy External sound card (FT-857D digi mode audio)
1 Tripplite 4 port Serial to USB hub (has FT-847, FT-857D, PCR-1000 and TS-140S connected)
1 Griffin USB Audio device (audio from PCR-1000 and FT-857D IF converter output)
1 Tripplite USB to Serial device (PCR-100)
1 Signalink USB (TS-140S I/O)
None seem to have issues communicating concurrently.
None are USB 3.0
Post by: W8JX on March 13, 2016, 09:32:58 AM
I have:
None are USB 3.0
None of them talk concurrently because USB does not support it. They are time sharing based on demand/needs. The devices listed are not very USB intensive and should get along okay.
Post by: K5TED on March 13, 2016, 10:39:13 AM
I have:
None are USB 3.0
"Typically a PC or laptop with have a few USB hubs internally meaning that not all port are hooked to same root hub and as long as devices are on different root hubs they can operate at same time."
So, in the context of a typical ham radio shack computer setup, and considering that most PC's have multiple root hubs in use (I count 7 on my shack PC at present), then the act of "communication" between USB devices and the PC, or between USB devices on different hubs, can indeed occur "concurrently", for all intents and purposes.
"communicating", "talk", "operate". Three words. Different meanings in context.
