eHam Forums => Misc => Topic started by: K5TED on September 10, 2018, 11:28:07 AM
Title: Any ideas what this is for?
Post by: K5TED on September 10, 2018, 11:28:07 AM
(http://www.radioscanner.ru/uploader/2010/norvegia_045.jpg)
Title: RE: Any ideas what this is for?
Post by: KC4ZGP on September 10, 2018, 11:51:30 AM
What in the heck?
Where ever did you find that picture?
A yagi pointed to the sky? A beacon? Hmmm....
Kraus
Post by: W8JX on September 10, 2018, 12:00:29 PM
It is likely a remote site that they fly over at altitude and collect data from time to time. Could possibly be a satellite up-link too.
Post by: N8YX on September 10, 2018, 12:46:22 PM
Look in the background.
Those are weather data instruments.
Post by: K7MEM on September 10, 2018, 02:34:53 PM
What in the heck?
I note an offset in the elements along the boom, so it is more likely to be a log-periodic. And, judging from the thickness of the elements, the whole array is very wide banded.
Post by: G3RZP on September 10, 2018, 03:54:02 PM
looks to me like an ILS Marker Beacon Antenna, but without a scale, it's hard to guess the frequency. Certainly doesn't look big enough for an outer marker which would be around 75 MHz. Inner markers are higher.
Post by: K3GM on September 10, 2018, 04:46:13 PM
Peter is correct.  It's a marker beacon antenna used in conjunction with the glide slope to an airport.  A single LPDA is usually used for an inner marker.  Dual antennas are often seen at an outer marker location.  The difference between the two is the the fly-thru time is shorter with two antennas than with one. Transmit frequency is around 75 MHz.
Post by: KC4ZGP on September 10, 2018, 04:56:24 PM
I was correct first. I suggested a beacon but I'm too mature to point  it out.
Oh gawd Kraus!
