eHam Forums => QRP => Topic started by: N7NV on May 04, 2019, 04:38:06 PM
Title: FT-817 on 13.8 switching power supply
Post by: N7NV on May 04, 2019, 04:38:06 PM
I wish to operate QRP only from home on an A.C. 13.8 DC switching power supply. All I read about is all the battery options..!  How do you hook it up with home AC power?  I can not find it mentioned anywhere.
Title: RE: FT-817 on 13.8 switching power supply
Post by: N2DTS on May 04, 2019, 05:59:21 PM
Yes, you plug it in the back of the radio.
Turn battery charge off so you don't damage the battery.
Post by: N2DTS on May 08, 2019, 05:27:07 PM
Some switching supplies make a lot of noise so compare between it and just battery power.
I have a new ft-818 which I think is a really cool rig.
Post by: KB1GMX on May 12, 2019, 10:26:45 AM
When operating at home any small 12-14V power source that can supply 3A will do fine.
I know it draws 2A for TX, but a margin is nice and there are an abundance of small
power supplies in that range or slightly greater.
I try to avoid switch mode power supplies but not all of them are terrible for noise.
I have one that is silent on all bands save for part of 80M even then its tolerable.
Not a brand name item but it was a cheap flea pickup.
The alternate is a 7Ah gell cell and a small matching charger for it.  then you
can use the radio even during a power failure.
Allison
Post by: LA9XNA on May 12, 2019, 09:59:45 PM
You can get 2-3A linear powersupplys very cheep.
If you are handy a bit  you cab probably build one yourr selves.
You get can a kit form Ebay for a few $.
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=3A+power+supply+kit&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=3A+power+supply (https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=3A+power+supply+kit&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=3A+power+supply)
Just add a 3A transformer of at least 15V.
It is a good training to learn some electronics.
Post by: N8AUC on May 13, 2019, 11:00:50 AM
The manual shows exactly how to hook it up to an external power supply.
You can use almost anything you like, a small linear or switching power supply, or a 12V gel or AGM type battery.
My FT-817 will run with external supply voltages as low as 9VDC.
It's a very versatile little radio.
Post by: SOFAR on May 13, 2019, 11:34:50 AM
 The supplied E-DC-6 DC cable may be used for DC connections.
https://www.manualslib.com/manual/339747/Yaesu-Ft-817nd.html?page=11#manual (https://www.manualslib.com/manual/339747/Yaesu-Ft-817nd.html?page=11#manual)
Post by: KI6WJ on May 22, 2019, 10:44:28 AM
If you don't already have a power supply , I use a SAMLEX SPS1206 and it s quiet.
Jim
Post by: N2DTS on May 23, 2019, 10:37:32 AM
I have had good luck with things like laptop and router power supplies.
Some are quiet, or at least they are in the lower ham bands.
You just need to make sure of the voltage, not all are regulated.
Now days, there are some small but high power regulated supplies.
At work we have some small supplies half the size of a laptop supply that do 14 volts at 8 amps.
Post by: WB4M on June 17, 2019, 03:02:43 PM
I used a small Astron 5 amp power supply (not a switcher) with mine.
