eHam Forums => Mobile Ham => Topic started by: KC7RYS on November 11, 2010, 08:48:30 PM
Title: Mobile in my work car....
Post by: KC7RYS on November 11, 2010, 08:48:30 PM
I do computer repair these days and could really benefit from having a radio for wx conditions during the winter. I drive a little Scion XB around, and would need something that I could remove from my boss' car when I'm not driving it.
Around here (Reno, NV) we've got 2m/440 all over the place and either would work. I'd be happy to stick to 2m for simplicity and cost. I don't have very much money.
What radio and antenna setup would work in this circumstance?
Title: RE: Mobile in my work car....
Post by: K0BG on November 12, 2010, 06:16:03 AM
Having been there recently, I suspect a good handheld might do the trick. You want one with an external microphone for obvious reasons, as well as one with extended coverage to the Wx (most do).
Post by: KC7RYS on November 12, 2010, 08:11:41 AM
Thanks k0bg, I suspected that might be the case. Who makes a good HT these days? I've been out of the hobby for a number of years, but I maintained my license.
Post by: K0BG on November 12, 2010, 08:56:34 AM
Everybody! If you compare all of the specs, they're very close to the same. The only major difference is the nameplate! Just pick one which has the features you want like the weather frequencies. Some of the latest have LiIon batteries, which makes them lighter, and longer lasting.
Post by: KD4LLA on November 12, 2010, 10:31:06 AM
If it were me I would purchase a used RS HTX-202.  It has a large display, decent built-in speaker, and is near intermod proof.  Downfalls are that it will not receive out-of-band (to monitor wx or public service bands) and if operated on a 12 vdc source (@ 5w) the case can get warm/hot.
I bought a Yaesu VR-5 a few years back and did not like the "smallness" of today's electronics.  No, I don't have overly huge paws, but little, trinket sized cellphones or HT's do not impress me.
Mike
Post by: KC7RYS on November 12, 2010, 07:25:50 PM
That's a really good idea. I don't like the microcity (made up word) of todays radios. I had an alinco dual bander a few years ago and I sold it. It felt, and looked, like a toy in my hands. I've got fat fingers and they keyboards are just too small. I had a Kenwood 2m radio before that, and it was nearly too small as well.
Post by: KJ1H on November 20, 2010, 12:05:11 PM
I've been using a Kenwood TM-271A in my personal car for about a year.  When I got a new job making deliveries in a company van, I found and picked up a second TM-271A at a local hamfest.  I modified the mounting bracket to hang the rig vertically from the edge of a large storage bin on the engine cover between the seats.  I run a 1/4 wave magmount on the roof, and have added a cigarette lighter plug to the end of the power cord.  I only run low power so that I won't draw too much current, but low power on this rig is 25 watts.  I wish I could run less!
But that's really my only complaint about the rig.  Read the reviews, and many will complain about having to go through menus to do much of anything, or the complexity of programming memories.  My experience is if you take some time to program your favorite repeaters into it, you don't need to access those functions while using it day to day.  Best of all, the built-in speaker is excellent, nice and loud for mobile use (my work van is old, clunky, and far from quiet), forward facing, and clear, even at max volume.
Personally, I like this setup better for mobiling than anything based on an HT.  And it's still 100% temporary and completely removable on a moment's notice.
Post by: KB3QWC on November 20, 2010, 05:51:40 PM
I second KA1ULT comments and do almost the same thing in a GMC 24’ box truck at work.  Using a Yaesu FT-1802 cigarette lighter plug with VHF 5/8 magmount antenna on top of the cab.  Mobile radios are easier to hear and use in a mid-sized truck.  Don’t really like using the lighter for power, but that is the only way to operate with driving a leased company vehicle.  I have about 30 repeaters pre-programmed for the Baltimore, Washington D.C., and Northern Virginia to use in the areas I am mostly driving in.  I only use a few, but nice to all programmed if you want to use one on the fly, so menu issue is not too bad.
Post by: W3LK on November 21, 2010, 02:16:21 PM
A 50w radio plugged into a cigarette lighter socket is a good way to have an under-dash fire. Most lighter sockets are 16 gauge wire and that simply won't take the sustained load without overheating and melting the insulation. Incidentally an under-dash fire generally takes out the entire dash, and if the fire is determined to have been cause by the overload, there is a good chance the insurance will not pay off because of an improper installation.
Under your circumstances, I'd go with the HT and mag-mount, as much as I hate mag mounts.
Post by: K0BG on November 21, 2010, 02:19:31 PM
Do you want to see what happens when you overload a cigarette lighter socket?
http://www.k0bg.com/images/wiring/wirefire.jpg (Look what the arrow is pointing to)
As Lon said, it just isn't worth the effort!
Post by: KJ1H on November 21, 2010, 04:50:18 PM
Which is exactly why I only run low power, which, on the TM-271A, draws at most 8 amps, which is about what a cigarette lighter itself draws (remember those? :) ).  Heating up a lighter is a temporary draw, and I don't transmit for long periods of time.  There are also fuses in my power cord, as well as the vehicle's own.
It's definitely not an optimum setup.  The rig in my personal vehicle is hardwired to the battery (as well as neatly installed right into the dashboard) because that's the right way to do it.  Since doing this isn't an option in a work vehicle that I don't own, I compromise, but still with an eye on safety.  I ran an IC-2100H off a lighter in a previous work vehicle on medium power for years without a problem.
Post by: W3LK on November 22, 2010, 03:20:20 PM
As for the fuses, wire can (and does) overheat and melt the insulation without any fuse blowing. Having seen more than one under-dash fire caused by overloaded wiring, I think you are asking for problems, but it's your boss's vehicle, not mine. :)
Post by: K0BG on November 22, 2010, 03:56:48 PM
Justin, regardless of what Lon and I tell you, you can do what you're most comfortable with. However, this raises a question: Do you really think you're safe?
Personally, after some 40+ years of operating mobile, I wouldn't be. And, I can bet Lon wouldn't either.
Post by: AD6KA on December 04, 2010, 11:09:34 PM
I assume you're going to ask your boss permission to operate from his car?
Or is it the "Better to beg for forgiveness than ask for permission" deal?   :D
With the cost of insuring vehicles and employees these days, as an employer I would say
"No, keep your eyes on the road and play radio on your own time".  :-[
Even to a fellow ham! ;D
Ken, AD6KA
Post by: KD7KGX on December 05, 2010, 03:22:17 PM
I use the auxiliary cigarette lighter plug in my '04 Dakota's console to power my mobiles.
I also ONLY transmit on low power (5w). On my new radio (FTM-350) I've programmed all of my memory locations to default to 5w. I can't see myself ever needing more than 5w if the repeaters are up and running... and if they're not, 50w isn't going to make much of a difference (1 S-unit).
I've run a mobile as an unattended cross-band repeater, but in that case I had a 40AH 12v battery in a battery box hooked directly up to the radio. I'd hook it up through the lighter plug using a 3A charge controller when I was driving to and from the location, and the controller isolates the battery from the vehicle.
So, with a 1/4-wave external antenna, 5W is plentiful, and a fused cigarette lighter plug is safe. Keep it to 5w, though!
Post by: K9YLI on December 29, 2010, 08:01:04 AM
My 97 chev mini van and now the  03 olds sillowette  have a  "power plug,"  front and rear.  trhey are not   lighter plugs anymore.
lap tops , cell phones, gps..  high current with high current wireing.
to mount a mobile rig, temporarily.  cut a piece of  2x4 that will slide into one of the handy  pockets they put in dashes now.
then mount the radio to the 2x4.   slide rigth out.
or if older vehicle and has an ash tray,
go to a junk yard, buy and ash tray to fit.
mount the radio  to the ash tray..
 restore the vehicle with the original ash tray, with out holes.
if  fuse box is under the dash, there should be a "batt"  position that
is hot all the time or   "acc"  that is hot withteh key  in either pos, run or acc.
alligator clip, and wire to feed the radio..
usually the mounting  is a bigger problem than finding power.
Post by: K0BG on December 29, 2010, 08:50:27 AM
The last thing you want to use to power a transceiver is an accessory power port! The wiring is inadequate, as most are wired with #16, and the voltage drop is excessive. If you want to see what happens when you use one for an amateur radio, go here: images/wiring/wirefire.jpg
The arrow is pointed at an accessory power plug.
Post by: K1CJS on December 29, 2010, 10:28:41 AM
In most newer vehicles, the cigarette lighter and the power port are wired to the same fuse.  And saying that the wiring is sixteen gauge may well be pushing it, especially on foreign cars.  The fuse used on that circuit is either fifteen or twenty amps, being that large to be able to take a current surge when the lighter is pushed in--but definitely NOT for extended current draw.
Another thing that you have to remember is that the usual automotive fuse is made to fail when the circuit is shorted--not when it is drawing what may well be the maximum current rating of the wiring.
If you change vehicles daily and want to be safer, get about ten feet of ten gauge dual color (red and black) zip cord.  Most ham electronics outlets on the internet sell the stuff.  Put a couple of battery clips on one end with a twenty amp fuse on the positive lead.  Run that in the engine compartment with twist ties to keep it out of the way of moving parts, poke it out of the hood and in through the weatherstripping on the passenger door.  MAKE SURE IT WON'T BE PINCHED ENOUGH TO BREAK THE INSULATION.
Put a connector on the inside end and plug your transceiver into that.  Now you can run it at any power level.  If you have the same vehicle every day, run the wire through the firewall and put terminal ends on the battery end of the wire.  Plug your transceiver in as mentioned above and you'll be good to go.
If your boss won't let you do that, there's a good chance he doesn't want you to use your rig in the vehicle anyway--and you'll be safer all around just leaving it home.
