eHam Forums => Amplifiers => Topic started by: W3AJJ on November 13, 2012, 11:01:19 AM
Title: Bird Termaline Model # 8201 max power in
Post by: W3AJJ on November 13, 2012, 11:01:19 AM
I need a dummy load for my 900w 2 meter amp.  Been looking at the Bird 8201.  I see that it rated at 500w continuous.  Will this handle 900w SSB since it is a lower duty cycle?
Title: RE: Bird Termaline Model # 8201 max power in
Post by: AD4U on November 13, 2012, 11:04:46 AM
500 watts continuous means "key down forever".  The Bird 8201 should EASILY handle the legal limit on a typical SSB duty cycle unless you transmit SSB into it for many hours.
Dick  AD4U
Post by: WB2WIK on November 13, 2012, 11:41:47 AM
It will handle it fine.
I use the same load quite often at >1kW PEP on VHF, and have been doing that since about 1978 or so -- hasn't failed yet. ;)
Post by: K0IZ on November 13, 2012, 12:20:51 PM
I have one.  Super dummy load.  I have pumped 3KW into mine for a two minutes continuous with only slight temp increase.
Post by: W3AJJ on November 15, 2012, 12:46:56 PM
Thanks all. Just wanted I wanted to hear.  Now I'll go looking for one.
