eHam Forums => Elmers => Topic started by: VA2FSQ on January 15, 2013, 05:57:41 PM
Title: Anyone want to see how a NCC-1 Antenna phaser kills noise?
Post by: VA2FSQ on January 15, 2013, 05:57:41 PM
I've been plagued by a neighbors high intensity discharge lights which he insists on running in the daytime.  So I bought a DX Engineering NCC-1 antenna phasing unit and an active receive antenna for the noise.  Was it a good purchase?
Here you decide!  Here is a spectrum from my P3 showing the 10MHz WWV signal (barely heard) before and after....
http://va2fsq.com/wp-content/uploads/2013-Jan-15-20-43-43.avi
Right click the link and store it locally for best results
Extremely good purchase!  Too bad there isn't a computer interface for it!!
Tom VA2FSQ
Title: RE: Anyone want to see how a NCC-1 Antenna phaser kills noise?
Post by: NI0C on January 17, 2013, 04:06:30 AM
Hi Tom,
Thanks for this link!  The improvement you're seeing is truly amazing.  I also have the NCC-1 and a single active Rx antenna that I use with my Tx verticals.  The NCC-1 output goes to my Rx antenna input.
I've never seen this dramatic an improvement in my signal-to-noise, but I guess my local noise sources aren't nearly as strong as yours.  I purchased the unit mostly for use on 160m, but I find that it works perhaps even better for me on the higher bands, such as 12 meters.
If I can find a place to put a second receive antenna, I might try using that.  Also, I'm considering using a couple of larger Rx verticals (such as those provided by Hi-Z antennas).
GL & 73,
Chuck  NI0C
Post by: VA2FSQ on January 17, 2013, 07:08:04 AM
Hi Chuck,
My primary tx and receive antenna is a HyGain AV640 mounted on top of the garage.  The "noise" antenna is about 30 feet away and I use a DX Engineering active receive antenna for this.  Since it is relatively close, it only works on 40 meters to 10m, but I really only need it on 40 and 20, the noise sources otherwise are acceptable.
Very worthwhile purchase.
Post by: NK7Z on January 17, 2013, 09:45:36 AM
Hi Chuck,
Have any of you used the MFJ-1025, (or 6), RFI reducer?  How does it next to the the DX Engineering one?
Post by: KB5UBI on January 17, 2013, 11:08:03 AM
I use the MFJ-1026 and I am impressed. Use an external noise antenna for the best results.
KB5UBI
Post by: WD4ELG on January 17, 2013, 05:45:54 PM
Wow.  That's pretty quiet, -140 dBm after kicking it in.
Post by: VA2FSQ on January 18, 2013, 08:33:49 AM
Hi Chuck,
Here's a write up
http://www.w8ji.com/mfj-1025_1026.htm
Post by: KK4YDR on September 19, 2016, 12:47:12 PM
Going to necro this thread.
The new NCC2is about to drop and I'm really interested in getting the whole shebang including botj active receive antennas.
Has anyone here Used the whole package with active rx  antennas? The ones they sell are coax fed and powered 8 foot CB antennas that mount to a ground rod. Any one use the full system and if so is it worth the expense?
Post by: KK4YDR on September 19, 2016, 02:12:18 PM
Ill start another thread that is fresh and new!
