Author Topic: copper lined rain gutter as dipole?  (Read 23490 times)
N1NI
« on: November 18, 2014, 08:34:58 PM »
I"m a very new ham (actually a second time around-er). Want to try all modes to see what I like. We live in an attached brick house with a slate roof and wooden gutters on 3 sides. They need repair and we are getting them lined with 16 oz. copper. The roofer is willing to split them wherever I say and I was thinking of turning it into a dipole. Probably have a total length of about 80 feet, about 30 feet up. I am worried about the effect of water combined with the wooden gutter (I read somewhere it will adverse affect things). And I am unsure how to feed this thing. Ladder line? Remote coupler at roofline? Rig is Kenwood TS 590s. I know these are pretty elementary questions but hope someone can help. Thanks in advance.
« Reply #1 on: November 18, 2014, 08:45:39 PM »
Probably the simplest thing is to split it in the middle as feed it as a dipole as you proposed.
Main problem would be making sure it doesn't leak at the joint.
I'd run ladder line to a balanced tuner at the rig, at least long enough to make sure the
antenna works well enough for what you want.  If it does then you can consider putting
a remote autotuner at the feedpoint (or nearby under the eaves.)
Is copper-lining a standard method of treating wood rain gutters?  I've never run into them,
and would think that a plastic insert would be cheaper and easier to work with (not to mention
less prone to copper thieves).   It probably isn't worth the expense of the copper just to
use it as an antenna, since you can achieve about the same thing by simply laying a wire
in a non-conductive rain gutter or attaching it to the roof or under the eaves.  But if that
is what you are going to have done anyway and there is no significant added cost, then
give it a try.
N1NI
« Reply #2 on: November 18, 2014, 09:14:59 PM »
Thanks. Keeping the wooden gutters because it is an attached house and needs to match our neighbors. Copper lining will allow it to last another century (important because I am 72 years old and expect to live to be 172). The copper part is my XYL's thing and I am just trying to take advantage of her irrationality about this. Planning to get an LDG KT-100 ATU but it only takes coax so I guess I need a balun, right? 4:1?
WB2KSP
« Reply #3 on: November 19, 2014, 06:09:55 AM »
And how would its resonance change every time it rains or when it fills with leaves.
« Reply #4 on: November 19, 2014, 08:45:29 AM »
Why not line it with vinyl instead and place a wire dipole in it at inner outside lip of vinyl gutter insert? using a cooper lined one will be very fussy to tune and greatly effected by water and debris.
WB2JNA
« Reply #5 on: November 19, 2014, 09:21:26 AM »
I agree with the suggestion of making a dipole out of insulated wire and just using the gutter to "support" the wire. I would feed it with ladder line and use a tuner at the radio. That will probably be much less influenced by water and debris in the gutter.
I assume that you can't string a dipole out in the clear and free of the gutter altogether? That would probably be even better. Good luck.
« Reply #6 on: November 19, 2014, 10:35:15 AM »
The copper does have the advantage of a fatter radiator, so the impedance changes
less with frequency.  With enough copper that may reduce the detuning effects of
water and debris, but if you are using it with a tuner anyway you can tweak it as
needed, so that shouldn't be a problem.
If you use a balun it should be a 1 : 1 current balun because the impedance
will vary over a wide range with frequency.  This applies whether the tuner is at
the feedpoint or in the shack.
« Reply #7 on: November 19, 2014, 01:48:50 PM »
Inside a wood gutter that itself will vary in moisture content and water in gutter would make it very unstable. A wire hidden in lip of a vinyl insert would be free of debris and water detuning it.
N1NI
« Reply #8 on: November 19, 2014, 02:13:22 PM »
Hmm. Lots to think about. XYL wants the copper, so I guess I do too (that's how I've stayed married for 42 years). The comments so far make sense (even the ones that disagree with each other). I might try radiating from the copper and if that doesn't work lay an insulated wire in the gutter. I don't have good supports on the property for a wire dipole (townhouse in a densely populated city with very little land front or back and no trees of my own). There will be a lot of copper in the gutter (probably about 5 inches formed to fit into the gutter) and also some connected flat sheets of copper over the doors to prevent icicles (about 2 feet by 4 feet), so that's kind of a wild card. I will use an ATU at the station end. Thanks for the balun info.
« Reply #9 on: November 19, 2014, 05:10:46 PM »
It will not do any good to lay a insulated wire in a copper gutter. With price of copper I would not line gutter with it where you cannot even see it.
KK4GGL
« Reply #10 on: November 19, 2014, 06:46:08 PM »
Is it possible for you to tack/staple  thin wire to the top edge of the gutter?
If you have shingles, you might consider inserting a thin wire underneath the shingles. You could make a dipole or a full loop that way.
Rick KK4GGL
« Reply #11 on: November 20, 2014, 04:47:22 AM »
If gutter is copper lined this is pointless.
KK4GGL
« Reply #12 on: November 20, 2014, 08:42:01 AM »
So says the self anointed expert on everything.
Rick KK4GGL
« Reply #13 on: November 20, 2014, 08:57:04 AM »
Another clueless troll.
KK4GGL
« Reply #14 on: November 20, 2014, 11:23:29 AM »
AHAH ahah HAhah HAH ahhahah HA ha aha ha...
Oh, you were serious?
Rick KK4GGL
