Author Topic: Need help with logging software Logic 9  (Read 8152 times)
N3ZC
« on: November 21, 2014, 02:03:53 PM »
I've had Logic 9 for a couple years. I haven't used it for a while (was sick, still am). I just had my SteppIR fixed. I open Logic 9, where all of my contacts are, and when I open a new Log page, and type in a call, hit the "Tab" key nothing populates. All of the slots used to populate, QTH, etc.. Now nothing happens?? I called HoseNose (software creator) and he acted like he was in a hurry and directed me to 2 videos on their Web page.(I have never changed anything, it worked before, but not now. No way I'm typing everything in with all the future contacts. Anyone have any ideas, or suggestions? Huh  Thanks in advance!  Tom N3ZC
W1MSG
« Reply #1 on: November 21, 2014, 03:38:11 PM »
I suspect that it uses QRZ to fill in the info and your subscription at QRZ may have expired .. Not sure if that is the fact but something to look into ..
N3ZC
« Reply #2 on: November 21, 2014, 05:50:04 PM »
Well, thanks, My QRZ subscription had expired and I paid $30  for a year's gold subscription. Now what do I do in Logic 9? Does my logon /password get inputted? In the call books drop down list there is a choice of QRZ.com or QRZ Subscription. No matter which I choose it doesn't stay that way. Must be a place in Logic 9 for a password?
KU6J
« Reply #3 on: November 22, 2014, 08:01:29 AM »
LOGic does its lookups from data entered for prior QSOs and from callbook data stored on your local disk. As far as I know, it can't do the lookups via an online database such as QRZ.com. Try this:
On your Log form, click the Log button that is in the upper-left of that form. In the drop-down menu that appears, select Setup (down at the bottom) to open the Log Form Setup window. Click on the Callbook tab and make sure that "Auto callbook lookup?" is set to Yes. To the right of that are several checkboxes that let you choose what gets looked up and filled into your form.
To refresh the callbook data that is stored locally on your disk, go to the main menu and choose Tools, Internet, Import FCC USA (K) Callbook (and/or choose one of the other Import options for foreign callbook info).
If this info doesn't help you solve the problem, you may want to post your question over on the LOGic forum:
http://www.hosenose.com/Forum/
ETA: I just found this over in the forum, so I guess it can do online lookups via QRZ.com:
http://www.hosenose.com/forum/yaf_postst1447_QRZ-COM-web-site-and-LOGic.aspx
« Last Edit: November 22, 2014, 08:08:11 AM by KU6J » Logged
Eric KU6J
Free SOTA Spot Monitor Software + RBNGate FAQ:
http://www.ku6j.com
K9IUQ
« Reply #4 on: December 09, 2014, 04:59:20 PM »
I've had Logic 9 for a couple years.  I called HoseNose (software creator) and he acted like he was in a hurry and directed me to 2 videos on their Web page
Do what I did a couple of years ago - dump Logic 9. I had been a Logic user since the early 1990's when I purchased Logic JR. I updated frequently and ended up with Logic 8. When Logic 9 came out I did the Demo. It was deja vu, meet the New Log, same as the Old Log.  Wink Then I found out Hosenose wanted $90 for an Update to 9. That was when I decided to say bye bye.
I assume you bought Logic 9 for $130 full non upgrade price, with only one year of support. After the first year you have to pay more $$$ to get support. So Hosenose doesn't want spend time on a past no longer paying customer and tells you to watch Youtubes and figure it out yourself. Then you find remember that your $30 QRZ sub has expired. Now you say "(was sick, still am)" This is a sad story.
Do yourself and pocketbook a favor. Find a different Logger. There are several good ones to pick from.
Stan K9IUQ
K5TED
« Reply #5 on: December 09, 2014, 06:07:47 PM »
It would be great if someone who is a serious contester would come in and detail what exactly is required for serious contest logging, and make suggestions as to which software fills the need.
Those of us who aren't 'serious' still want to have solid logs for reference.
N5MOA
« Reply #6 on: December 09, 2014, 07:53:19 PM »
I'm not a serious contester, maybe semi-serious for the times I am on during whichever test I'm in.
N1MM+ is hard to beat for a contest logger.
« Reply #7 on: December 09, 2014, 11:53:12 PM »
Agree, N1MM+ is the best contest logging software and it's free.
