Author Topic: th79a programming software needed  (Read 3480 times)
KM4IY
« on: November 22, 2014, 05:12:13 PM »
i have a need for the th79a programming software but i'm unable to find anything specifically designated for it.  do you have any ideas where i might locate what i need?
thank you
KB8YVC
« Reply #1 on: December 05, 2014, 02:36:15 PM »
You are the programming software, unfortunately Angry.  That radio doesn't support programming via PC.  If you know somwonw who has one programmed, then you could do the over the air clone process.  See below:
If you have both radios please hold down the -0- key / PAG L Key when you switch on the radio. So you see the letters CLONE on the display.   Please push the ptt on the radio which is to be the master.  It takes a time to transmit all memory with maybe names, call sign etc.  After Clone is finished you see END written in Display. Best is to switch of both radios. After switching on again you will have two same radios.
