Author Topic: Tecsun 600 timers  (Read 5291 times)
K2CPE
« on: May 29, 2015, 02:09:28 PM »
I have a Tecsun 600, which I am unable to deactivate the timers. No matter what combination of button pushes, it shuts off after 6 minutes. The manual is no help (for me) as it is written in "chinglish". Any advice will be appreciated.
Rich  K2CPE
KAPT4560
« Reply #1 on: May 30, 2015, 05:17:24 AM »
 The PL-600? The instruction manual isn't that hard to follow. I've seen worse.
 See p. 11 for activating/deactivating the timers. Is TIMER A or TIMER B displayed in the window? If so, that means that the timer is activated. If you want to deactivate the timer(s), simply press the TIMER A or TIMER B button so that neither TIMER A or TIMER B is showing in the display window.
  http://www.fmuser.net/upLoad/down/month_1403/tecsun-pl600-manual.pdf
 All these Chinese radios follow similar formats for setting up your desired options. My CCraneSW (Tecsun RP2100) sets up the same way.
 If you are still having trouble selecting the timers on or off, try a 'reset' (p. 18). You may lose what you have already programmed, so write everything down so you can re-enter it afterwards.
K2CPE
« Reply #2 on: June 01, 2015, 02:00:21 AM »
Hello Kapt4560,
If (when) Timer a is showing,and I press the timer a button, the timer a icon does go out, but is replaced by the timer b icon....without me pressing the b button. Turning off either only causes the other to turn on. Maybe its just a defect with my particular PL 600? Anyway, doing the "re-set" did the trick.....all timers now deactivated. I didn't need to write down "saved to memory" stuff because I don't save anything. I just use my 600 for casual listing to am & fm broadcast and hams chatting on ssb and very occasionally for shortwave broadcast listening.....not much there these days compared to when I got the radio bug growing up in the 50's. But thanks for the "reset" tip.
Rich  K2CPE
