Author Topic: Speaker Mic with display  (Read 3101 times)
KC5GGE
« on: September 10, 2015, 06:56:39 AM »
I currently use a hand held (I switch between a Baofeng and Kenwood) in my car connected to an external antenna. It works well if I stay on the same frequency. But, changing frequency, setting the radio to scan, stopping scan etc, requires picking the radio up from the cup holder, which I would rather not do while driving.
I would like a speaker mic that has a frequency display and buttons to control the radio. I have never seen one like that before, so I doubt it exists, but thought I'd ask on here and see if anyone has run across this, specifically for a Kenwood handheld (TH-F6A or TH-D72).
M0GVZ
« Reply #1 on: September 10, 2015, 09:57:11 AM »
Unless the manufacturer offers it then no. It would require more than just a couple of jack sockets to do.
KC5GGE
« Reply #2 on: September 10, 2015, 10:06:17 AM »
I figured since my Kenwoods have a USB port, that could be used to send display data. Guess there just isn't a big demand for it. I will eventually put a mobile radio in my car. Thanks.
AB2M
« Reply #3 on: September 11, 2015, 08:13:30 PM »
Yaesu had one for the Ft-530 a few decades ago.  Haven't seen one since, to be honest.  There are mounts from RAM and others that can hold an HT in a more visible location, perhaps that might work?
KC5GGE
« Reply #4 on: September 12, 2015, 09:40:28 AM »
Thanks. I will check out RAM mounts.
N1DDS
« Reply #5 on: September 15, 2015, 07:24:02 PM »
The solution to this problem is a proper mobile radio.  Look for something inexpensive.  There is plenty out there.  I was in the same position as you.  Even if you have young eyes, the display on an HT is too small for use while mobile (car).
KC5GGE
« Reply #6 on: September 15, 2015, 07:28:30 PM »
Yep, I will need to do that. It can be tricky to find a way to run the power cables through the firewall.
W3POR
« Reply #7 on: September 16, 2015, 12:07:05 PM »
That should not be difficult.  I have a 2003 Subaru and found two or three places to route power cables through the firewall.
