Author Topic: Ramsey DDF1 thought  (Read 18424 times)
KD8VQH
« on: January 20, 2016, 08:02:56 AM »
I just got the DDF1 kit but haven't started putting it together. My thoughts are to put the antenna switching board in a a project box to keep inside the car so it is not in the elements. I plan on making my own NMO mag mount antennas. I have seen articles that say to use equal lengths of coax for each antenna. Would it be better to use RG58 or can I use RG174? I also plan on using connectors to fit what ever coax I end up using so I can disconnect the antennas from the switching board when not in use. My mag mounts will be 2 inches in diameter. I have diodes and inductors coming in the mail today to build my mounts. If these ideas will not work I will go with the plans with the kit.
Thanks in advance
Wes
« Reply #1 on: January 20, 2016, 10:34:02 AM »
If the cables are short then RG-174 is fine.  For longer cables (like reaching inside the car) then I'd use
RG-58 for lower loss.  (Doppler systems tend to be lacking in sensitivity to start with.)
You might get some ideas from K0OV's improved doppler antenna / switching system here:
http://www.homingin.com/newdopant.html
Certainly all the coax lengths have to be identical for the system to work properly.
Oh, and don't use a foam-dielectric cable such as RG-8X if you are going to be running it into
the car through the door jam - the foam is much easier to compress when slammed in the door
than the solid dielectric in RG-58.
KD8VQH
« Reply #2 on: January 20, 2016, 02:26:20 PM »
Thanks for the information. I have been to the homing in page and have done a lot of reading. I have a lot of RG58 cable with the solid dielectric to use. I will put connectors on and connectors in the box, all numbered for each antenna and numbers on the antennas. I will use the antennas with the kit if need be and set the box up so I can hold it on the roof of the car. Our club is planning some fox hunts this year. I have a "fox box" ready and working. Once I get the direction finder assembled I can use the fox box to test it out.
Thanks again for the information
Wes
KO4LZ
« Reply #3 on: January 24, 2016, 07:54:19 PM »
Incidentally, if you're interested in learning more about how Doppler and other DF methdologies work, you can download the slides from my workshop at VA Tech here:
https://wireless.vt.edu/2015_%20slides/document.pdf
I'm an application engineer at Rohde & Schwarz and one of my specialities is interference hunting / direction finding.  Would love to show up for a foxhunt one day with some of my "work" tools   Smiley
KD8VQH
« Reply #4 on: January 25, 2016, 07:28:30 AM »
Paul,
Thanks for the link! I will study the material. Our club is planning on doing some fox hunts this year. There is a member from another club in the area that has been helping me. I have my fox box ready to go and he has some low power foxes that we will use in a local park. We are hoping to do a demo at our April meeting.
Thanks again for the information!
Wes
ESTEFAN2020
« Reply #5 on: July 03, 2016, 05:14:32 PM »
http://www.handi-finder.com/
Here is another 2 antenna df like ramsey df1 but is not bulked up price.
I like the http://www.homingin.com/newdopant.html
4 antenna style, but discouraged when the price hits $100+ for a kit.
