Pages: Prev 1 ... 84 85 86 87 88 [89] 90 91 92 93 94 ... 164 Next   Go Down
Author Topic: LoTW / QSL Received  (Read 652294 times)
KD0PO
« Reply #1320 on: November 29, 2017, 05:21:37 AM »
@ Obie N5VYS and Ray KD0PO
not only the 2015 logs but all my logs since 2001, look at this one:
Today is Wed, 29 Nov 2017 UTC
You are DL1NKS
Log Off
You have 516,251 QSO records
You have 171,669 QSL records
tnx for all the QSOs
Steve, DL1NKS
Welcome Steve, glad you're here and thank you for joining LoTW..
Best 73
Ray
N5VYS
« Reply #1321 on: November 29, 2017, 06:25:19 AM »
You are DL1NKS
Log Off
Steve, DL1NKS
Thanks Steve, Your confirmations via LoTW are very welcomed.
Obie N5VYS
KD0PO
« Reply #1322 on: November 29, 2017, 05:38:38 PM »
9X0TA via LoTW
New phone contact
Ray
AA6YQ
« Reply #1323 on: November 29, 2017, 08:33:27 PM »
Steve, the percentage of the confirmed QSOs should be much higher, probably closer to 50%.
In my experience, Steve should not expect an overall 50% confirmation on a log going back 18 years.
Since being licensed in January 1990, I have logged 24,538 QSOs in CW, Phone, RTTY, PSK, Pactor, and FT8. My overall LoTW confirmation rate is 27%. Dividing my log into three 9-year intervals and determining the LoTW confirmation rate for each interval reveals that confirmation rate is inversely proportional to age:
1990-1999: 11%
1999-2008: 28%
2008-2017: 48%
Steve's overall 33% confirmation rate for QSOs made since 2001 is consistent with this pattern.
There is another factor: digital mode ops are more likely to QSL via LoTW because they are more likely to use a computer for logging; from my entire log:
Phone: 19%
CW: 27%
Digital: 37%
Thus the higher the percentage of digital mode QSOs you've logged, the higher your LoTW confirmation rate will likely be.
Slicing and dicing the digital modes shows both of these factors at work:
Pactor: 0%
PSK: 33%
RTTY: 38%
FT8: 74%
All FT8 QSOs were made since July, so their confirmation rate is driven by both their recency and their high probability of computer logging.
« Last Edit: November 29, 2017, 08:36:14 PM by AA6YQ » Logged
#1 DXCC Honor Roll, DXCC Challenge 3000
VE3VEE
« Reply #1324 on: November 30, 2017, 12:54:13 AM »
Dave, thanks for the analysis. Makes perfect sense now.
Marvin VE3VEE
N3QE
« Reply #1325 on: November 30, 2017, 03:33:17 AM »
to: Uses LOTW? Yes
How about to Uses LOTW? Yes yes, five hundred thousand times yes!
And Clublog too. Below shows very-good-but-not-quite-perfect cross-reference match both ways on Clublog:
Thanks for all the Q's, Steve!
VE3VEE
« Reply #1326 on: November 30, 2017, 05:51:38 AM »
3C1L - Equatorial Guinea
3C0L - Annobon
November 30 - Update
"QSL cards are in printing. Soon QSLs for direct OQRS and sponsor QSOs will be mailed. On 10th of December also priority LoTW upload will be done for sponsor and direct OQRS QSOs."
Source: http://www.lral.lv/3c0l_3c1l/index.html
Marvin VE3VEE
KD0PO
« Reply #1327 on: November 30, 2017, 06:47:13 AM »
ZL9BQD from 1988 via LoTW
New Zealand Subantartic islands
Ray
DL1NKS
« Reply #1328 on: November 30, 2017, 08:25:34 AM »
Wow. Much input here. So I hope I did my homework right:
changed qrz.com and here are the infos from the log: year/QSO
2001      1626
2002      2786
2003      4476
2004      5706
2005      9230
2006    21008
2007    20823
2008    25522
2009    29765
2010    31748
2011    37677
2012    39379
2013    42848
2014    49648
2015    71898
2016    69846
=       516568
CW: 55.96%
Phone: 44.04%
@N3QE,
hi my good CW  and contest friend…
Yes LOTW was easy for me because of using Clublog before I only had to push one button and all my QSOs were exported from Clublog to LOTW. great.
Sorry for our missing QSOs I think its me having the bad ears…
Steve DL1NKS
KM4SII
« Reply #1329 on: November 30, 2017, 08:47:47 AM »
Hi Steve! Thanks for the QSO confirmation as well from our QSO last month! I remember you mentioning to me that you had seen my posts on eHam Smiley Happy to see you join the group!
73 de KM4SII - Mason
VE3VEE
« Reply #1330 on: November 30, 2017, 04:28:21 PM »
S79K - Seychelles - has uploaded to LOTW.
Marvin VE3VEE
VE3VEE
« Reply #1331 on: December 02, 2017, 12:53:01 AM »
VQ917JC - CHAGOS ISLANDS - is on LOTW now.
Marvin VE3VEE
« Reply #1332 on: December 02, 2017, 09:16:20 AM »
Steve, the percentage of the confirmed QSOs should be much higher, probably closer to 50%. I wonder if some of your logs may be in your local time instead of UTC.
If his logs go back to 2001, his match rate should not be so high.  LOTW was insignificant until 2004 and took a while to ramp up, too.  A lot of folks have not bothered to go back to QSO number one (those may be on paper or otherwise hard to access) and in their individual cases, decided to upload from whatever date they registered.
AB8MA
« Reply #1333 on: December 02, 2017, 05:15:45 PM »
His Club Log shows 516,568 QSOs logged between 2001-03-24 07:20Z and 2017-11-12 12:43Z
« Reply #1334 on: December 04, 2017, 06:34:32 PM »
OH0Z on 160 CW confirmed by LoTW!  Worked this past weekend in the ARRL 160 contest.
Zack W1VT
Pages: Prev 1 ... 84 85 86 87 88 [89] 90 91 92 93 94 ... 164 Next   Go Up
