Pages: Prev 1 ... 159 160 161 162 163 [164] 165 166 167 168 169 Next   Go Down
Author Topic: LoTW / QSL Received  (Read 670506 times)
K5PS
« Reply #2445 on: September 11, 2019, 08:25:37 AM »
I have seen them ( and called them) on every band from 80 thru 15 meters.  dozens of times and hundreds of calls. I have never been able to work them. They are as deaf as a post. They often have good signals, But I see dozens of guys calling that never seem to be able to get them.  I think you are going to have to have a really good antenna and some real power to get these guys. I assume they are running power, and have an incredible noise level at their location.
Other than this QSO, I've only ever worked them on 30m and it was a struggle. I've tried working them on 80, 40, and 20 without success.  A local friend of mine tried for over a week on 30m before finally getting through.
Worked them on the second call on 60m - they had a good signal and did not seem to have many calling them there. Was hoping they were headed to 80m when I saw them leave 60m, but alas they went to 30m.
Dumb luck on my part - just happened to be on PSKReporter looking at how well my signal was being received on 20m when I saw they were on 60m.
GL to you in your efforts.
All generalizations are false
« Reply #2446 on: September 11, 2019, 08:50:38 AM »
It has gotten to the point I have thought about adding them to my "ignore" list in JTalert So I don't have to listen to "DX !" for hours at a time.  I would love to work them on any band as they would be a new country for me. I just don't think it likely with their profound deafness.
ARRL Missouri Technical Specialist
AC4GW
« Reply #2447 on: September 11, 2019, 02:12:28 PM »
S92HP on LoTW for a 60m FT8 QSO.
Was checking PSKReporter when I saw they were monitoring 60m. Didn't see a spot for them but, when I went to listen they were calling CQ.
I worked S92HP on 17m FT4 earlier today and it has already been confirmed on LoTW. I will say I sent then a -03 and they sent me a -19. Maybe I've been lucky but I also have then on FT8 on 30, 40, 60 and 80.
KM4SII
« Reply #2448 on: September 11, 2019, 04:03:43 PM »
Sometimes they seem to hear very well, but now they seem to be having a harder time hearing.
In July I sent a -17 and received a -11 from them on 17m and in August I sent a -16 and received a -06 on 30m. I have zero noise on either of those bands.
Now when I have been hearing them even when their signal is into the pluses, they barely seem to hear anyone, let alone me. Maybe a new noise issue has popped up?
Mason - KM4SII
« Reply #2449 on: September 11, 2019, 05:44:37 PM »
May I ask how much power you were running and a general idea of your local noise level for that 16 dB difference in signal report.  16 dB is the difference  25 watts and 1000.
« Reply #2450 on: September 11, 2019, 05:45:52 PM »
Mason - KM4SII
That is what I am thinking.  Someone has started an arc welding business next door to them.
AC4GW
« Reply #2451 on: September 11, 2019, 06:35:31 PM »
K0UA, my noise level on 17m is pretty low. I was just using a wire antenna. I'm sure their signal would have much stronger on a yagi. I was running about 300 watts. I don't normally run the amp on the higher HF bands but I will if I need it to be heard.
« Reply #2452 on: September 11, 2019, 06:40:41 PM »
XR0ZRC paper QSL
« Reply #2453 on: September 11, 2019, 06:46:21 PM »
But with 100 watts you would not have made it. 300 is 4.77 dB above 100
This helps explain why I can't make it. And gives me an idea of how strong they need to be before I bother calling them.
KM4SII
« Reply #2454 on: September 11, 2019, 08:16:25 PM »
KG4WV 10m SSB via LOTW from back in 2016
N5CM
« Reply #2455 on: September 12, 2019, 05:19:43 PM »
XR1RRC; 30m CW via QSL card in today's mail.  Also received QSL card from XR0ZRC for QSOs previously confirmed by LoTW.
N5MOA
« Reply #2456 on: September 16, 2019, 06:04:11 PM »
T6AA LOTW, 30m qso 2 days ago.
#285 on 30m, Challenge #2512 confirmed.
OZ8AGB
« Reply #2457 on: September 17, 2019, 06:40:15 AM »
T6AA yesterday on CW 30m
K5PS
« Reply #2458 on: September 17, 2019, 06:51:25 AM »
Some pleasant stuff in the mailbox yesterday:
QSL from 9M2TDX for a 40m FT8 QSO. New one for me on digital.
Also received my XR0ZRC QSL.
AC4GW
« Reply #2459 on: September 17, 2019, 07:38:48 AM »
I got ZD8SC confirmations on LoTW this morning.
Pages: Prev 1 ... 159 160 161 162 163 [164] 165 166 167 168 169 Next   Go Up
