Pages: Prev 1 ... 48 49 50 51 52 [53] 54 55 56 57 58 ... 164 Next   Go Down
Author Topic: LoTW / QSL Received  (Read 653197 times)
N3QE
« Reply #780 on: January 30, 2017, 06:06:12 PM »
Quick LOTW confirmation for my 160M QSO with GU4YOX! Happy day!
N5VYS
« Reply #781 on: January 30, 2017, 07:20:16 PM »
HK1R & PJ2T 160M via LoTW.
Obie N5VYS
« Reply #782 on: February 01, 2017, 12:31:14 PM »
7Z1SJ on 160M CW via LotW!  My first Asian QSO on Top Band!
OX/OZ1LXJ and 4O/KC0W paper QSLs, also on 160 CW.
Zack W1VT
KB2FCV
« Reply #783 on: February 01, 2017, 12:41:54 PM »
HK1R, XE2X, PJ2T - 160m Lotw
A45XR, VK1MA - 80m Lotw
VE3VEE
« Reply #784 on: February 01, 2017, 04:18:37 PM »
VU7MS - Lakshadweep Islands DXpedition December 2016 QSL card received in mail today.
Marvin VE3VEE
W6GX
« Reply #785 on: February 02, 2017, 05:36:08 AM »
FY5KE and CN2AA uploaded to LoTW.  My CN2AA confirmation on 160m has brought me to 96 confirmed on 160m.  I'm so close and yet so far away from 100 Cheesy  Just one or two more EU openings on 160m would be nice.  160m band condition has been crappy lately...
Jonathan W6GX
KB2FCV
« Reply #786 on: February 02, 2017, 06:24:01 AM »
Jonathan W6GX
Congrats Jonathan!! I checked and my CN2AA is there also   Cool
You are a bit closer than I am... 30 confirmed here now  Grin
W6GX
« Reply #787 on: February 02, 2017, 06:51:24 AM »
Jonathan W6GX
Thanks James.  It took me a while to get everything figured out on the hardware needed for 160m.  I went through several TX antennas and now I have a dedicated RX antenna which helps tremendously.  Believe me it's not an easy road to get to this point.  There was a lot of trials and tribulations.
My 160m confirmed total jumped up significantly recently as I had several EU openings in Dec. and Jan.  Prior to Dec. 2016 I only had one EU contact (E74AW) from Feb. 2016.  I have worked CU many times in contests but I haven't been able to confirm those contacts despite a great deal of effort using direct QSLs.  Figures.  And CU wasn't in the recent 160m contest.
Jonathan W6GX
K5PS
« Reply #788 on: February 02, 2017, 06:58:08 AM »
Thought I had worked CN2AA as well on 160m, but when I checked there's no confirmation. Maybe better luck next time.
Did get a PJ2T confirmation earlier, and a match on ClubLog for P40AA, so I'm +2 (15 total) on 160m.
All generalizations are false
« Reply #789 on: February 02, 2017, 07:03:26 AM »
My 160M QSO with CU2CE was really wierd.  Not only was it on Monday, but it was also the 2016 leap day.  It was on SSB and confirmed via LoTW!
W6GX
« Reply #790 on: February 02, 2017, 07:12:23 AM »
I have a total of four contacts with CU on 160m.  Two with CR2X and two with CU2KG.  CU2KG's last LoTW upload was in 2012.  I guess 2012 was the year Martti abandoned LoTW.  I have sent Martti both buro and direct QSL cards with more than sufficient postage.  But so far no return QSL.  I guess Martti is too busy traveling and has fallen behind on his QSLs?  He must get a ton of QSLs as he now doesn't do LoTW anymore.
Jonathan W6GX
W6GX
« Reply #791 on: February 02, 2017, 07:13:49 AM »
Welcome to 160m.  It's a fun band.  What kind of TX and RX antennas do you have on 160m?
Jonathan W6GX
KB2FCV
« Reply #792 on: February 02, 2017, 07:42:09 AM »
I'm at the very early stages of my 160m setup. I am just using my 100 foot dipole for now, which I know is far too short. My first plan for improvement is a receive antenna. I'm considering a k9ay antenna since it fits on a small lot... or.. if I can figure out how to get over the river.. I might sneak a beverage antenna in as there is a ton of unused / un travelled woods. For transmit I'll probably eventually put up an L. Lastly, I would want to build a 160m amp or change out my SB-200. I am hoping to get to Dayton this year and check out the new location.. so perhaps I'll be looking at some new shack / antenna additions Smiley
W6GX
« Reply #793 on: February 02, 2017, 07:52:10 AM »
Very good James.  Just remember this.  On 160m there's no substitute for size.  If everything else is equal the bigger the better Grin  I would go for a beverage antenna if you can sneak one in.  You will have to consider wildlife damage if the area is wooded and the beverage is hung low.  By the way, the worst thing to happen to a 160m DXer is to have a RX antenna break and the DXer not knowing it.  Since you can't transmit into a dedicated RX antenna,  you cannot test a RX antenna other than by doing a physical inspection or a comprehensive RX test.  As me how I know Cheesy
Jonathan W6GX
N3QE
« Reply #794 on: February 02, 2017, 07:55:57 AM »
If you tie your dipole's feedline together at ground level, and feed the feedline like a "vertical" or "Marconi T" against ground (better, ground+radials), you have a very nice antenna there.
I am very happy with a small K9AY loop for receive.
Pages: Prev 1 ... 48 49 50 51 52 [53] 54 55 56 57 58 ... 164 Next   Go Up
