Author Topic: Fiberglass Camper Shells & Antennas  (Read 3699 times)
NT6U
« on: September 17, 2016, 04:40:00 AM »
I am installing a new fiberglass Snug Top shell along with my new HF & VHF mobile install (Earlier thread 480 HX install by NT6U).
      Would it be worth the money to line the interior of the bottom inside of the shell with a copper mesh or strapping (Georgia Copper) or would a simple 20ga. flat strap galvanized sheet metal serve the same purpose as a electrical counterpoise?
     I intend to electrically bond this strapping @ all 4 corners to the frame with copper strapping.  I also intend to drill through the fiberglass roof for my antenna mounting, of course adding structural metal to support an antenna.  I also intend on RE-fiber glassing over the added metals to keep them secure, before I reinstall the camper shell carpet.
I will be "hiding" all the work with carpet when I'm done so I don't care what it looks like between the glass shell and carpet.
Does anyone have any other suggestions? Wire as radials ect?  Am I overthinking this?
Thank you.
KG4RUL
« Reply #1 on: September 17, 2016, 05:38:51 AM »
Consider that a normal car body is made from sheet steel not copper.  So, since you have to add metal for structure anyway, use it for a ground-plane.
AI7PM
« Reply #2 on: September 18, 2016, 01:43:51 PM »
I tried this for VHF/UHF. Sheet metal, either top, and/or on the bottom of the topper didn't workout for 1/4 or 1/2 wave on UHF. I tried everything I could come up with. Grounds, and not, in every way you could think of. The Comet NR770 dual band would match. It's 5/8 over 5/8 on UHF. That gave me 1.4:1 It's 1'2 wave on VHF, and was 1:1.
On VHF I could get a good match on 1/4 and 1/2 wave antennas.
A bird strike (LARGE bird) cleaned both of them right off of the topper, so I just added two more NMOs to the cab roof and went back to commercial grade antennas with springs.
I kept one position on the topper. I removed the sheet metal, and installed copper ribbon radials, then repaird and sealed the roof. Still no luck matching 1/4 or 1/2 wave on UHF. But again, good on VHF, so its the APRS antenna now.
K6CPO
« Reply #3 on: September 19, 2016, 11:51:14 AM »
I have a fiberglass shell on my truck and I mounted a single 2 meter/440 antenna in the middle of the cab roof.  I've seen other truck owners get good results from mounting a half-wave antenna on the edge of the hood.  I have a second mount on the driver's side of the hood ready to use if I ever need it.
VE3HIX
« Reply #4 on: September 21, 2016, 12:36:04 PM »
There is more to this than getting a good ground plane or a 1:1 match, if the non-metallic cover is over a passenger compartment. In Europe, you need to shield the passengers from RF. A non-metallic roof would require a completely shielded liner such as the covered metal liner inside a military Land Rover that has a fiberglass top. Even a soldered connection to an NMO inside a truck roof with a steel top exposes a tiny bit of RF to the passengers, and must be shielded.
If the installation is on the back cap of a pickup truck with no passengers underneath, please disregard.
Just a heads-up.
Cheers,
Bob
VE3HIX
