Author Topic: MD-380 Audio Stuck In Mute  (Read 6632 times)
WA9AFM
« on: January 11, 2017, 07:24:29 PM »
Turned on my MD-380 and there was no receive audio.  Noticed an 'X' next to the speaker icon on the screen.  Can't find any command/setting in the menu to cancel mute.  Anyone had this situation?
VK5CQ
« Reply #1 on: January 12, 2017, 04:54:12 AM »
Did you happen to program this MD-380, at all?
If so (of it you got it used, & someone else did),
it's possible/likely that Button 1 or Button 3 got
programmed.
For each Button, there's a Short- & a Long-Press
option, so - depending on how long you (even
unintentionally) pressed one of these - you may
have activated an unexpected mode.
When I got a new MD-380 (this month), its
Button 2 (below the PTT) was programmed
like other radios' Monitor (except I don't think
it listens to Repeater-Input freq.; check that pt)
So, I'd Short-press & - if I got NoJoy,
then I'd Long-press each of these Buttons,
one press at a time, & see if you get audio.
Of course, arrange to have a signal nearby,
to open the squelch.
If the above fails, maybe see if some Receive
Decode is waiting for a CCTSS-tone or DCS-
code to be received.
Best way, of course - even without testing -
is to use the Programming s/w (that comes
with a new MD-380, as does its USB cable) &
do a "Read" then check channel for DCS or CTS
Encode(s) on Receive
In same program, open the Buttons page &
see if one or both are set to some odd function.
(I like Button 1 for do High / Low POWER &,
maybe "All Alert Tones On / Off" for Long-press.
For Button 2, I like (default): Monitor (ie, Open Sq
or Not Open, & maybe "Tight / Normal Sq" f Long).
Let us know how you solve it... I could be way off. :-)
PS S/W also lets you allow Radio's Menu add a
"Program Radio" (not shown, by default, when new)
so you can fiddle with a few more parameters, &
change freq's of channels, etc.
WA9AFM
« Reply #2 on: January 12, 2017, 07:04:13 AM »
Thanks for the response.  This is a new radio and I'm the original owner.  It was reprogrammed with a new file about a month ago and was working fine.  Again, when I powered it up two days ago, the audio circuit is muted.  I don't even get the 'power up signal'.  Are you aware of a 'hard reset' procedure?
TMW
WA9AFM
« Reply #3 on: January 12, 2017, 06:42:03 PM »
Got it fixed!!  Had to set Tones/Tone Alert to 'On' and realized I had Ver 1.30 vs 1.32 installed.  All in now well in DMR Land.
VE6JMK
« Reply #4 on: May 21, 2019, 12:28:53 PM »
Just had this same problem on a MD-UV390, and this solution helped with a quick fix, thanks for posting it.
KF0OU
« Reply #5 on: July 24, 2019, 04:06:18 PM »
So having tones turned off also mutes the audio?
