Author Topic: 811A Socket=Loose pin contacts--how to fix? Tighten up?  (Read 4051 times)
« Reply #15 on: April 30, 2017, 02:32:35 PM »
Off topic but since it was already mentioned....Ive tightened up real Johnson 3-500/4-250, etc sockets that werent completely black from heat that remained good once the slowed down Heathkit  fan was overhauled.
AND customers were advised to replace the missing top air deflector and dont block the air flow; both of which are causes of socket problems.
Chinese AL-811 sockets are pure junk after a few years as mentioned.
VK3BL
« Reply #16 on: April 30, 2017, 04:34:59 PM »
I've got a couple of NOS EF Johnson 4-250 sockets that have gone completely black on the pins too... silver plated pins will naturally tarnish unlike cheaper non plated sockets.
Just don't want the OP to get confused between the two different issues.
« Reply #17 on: April 30, 2017, 05:15:20 PM »
Yeah, harmless tarnish is a lot different than heat!
N6QWP
« Reply #18 on: April 30, 2017, 05:38:52 PM »
Think that I have found some NOS E.F. Johnson sockets.  Problem with replacing them on the 30L-1 is that since they are mounted horizontally, they can only be accessed by dismantling the back panel.
Art Collins designed some pretty solid gear.....but did not make it easy for users to get "into them".
Will do what I have to.....BUT, STILL HAVE NOT DETERMINED WHAT PART IS CAUSING THE FLASHOVER PROBLEM.....know that it is socket related, but what component could be shorting, or opening up or causing the extreme current to be drawn....resulting in this one tube going ballistic???
Still waiting for some input as to the exact cause of this issue.  Anyone have any ideas?  Care to venture a guess?  What should I be looking for?  Some pin moving too close to some other component?  I'm thinking maybe something to do with the bias?  What else could cause it?
Someone thought it would have to do with the anode.....but that connection is solid.  Must be something happening with the socket.  Still looking for some help here.
« Last Edit: April 30, 2017, 05:58:53 PM by N6QWP » Logged
