Author Topic: Adhesive for Use at Radio Frequencies  (Read 7877 times)
W9BVG
« on: September 23, 2017, 08:36:30 PM »
Anybody know of an adhesive with good dielectric characteristics at 3.5-30 mhz? I need to secure an air-wound coil to a plastic strip, but I want to be sure the adhesive won't short the coil windings at these frequencies. I've read that polypropylene hot melt adhesives are good for this purpose, but I think availability of those is minimal.
« Reply #1 on: September 24, 2017, 01:11:12 AM »
I found that some of the 5 minute epoxies produced no measurable drop in Q. But not all....The epoxies for long term structural use such as Araldite were another matter altogether.
DL8OV
« Reply #2 on: September 24, 2017, 04:18:39 AM »
Most epoxy resins seem to be fine and so far as I can see the cyanoacrylate adhesives (A.K.A. Crazy Glue) are totally transparent at RF. If in doubt about glues and plastics put a small sample in the microwave oven for a few minutes and see how warm it is afterwards, the good stuff should still be cool.
Peter DL8OV
N8YX
« Reply #3 on: September 24, 2017, 06:04:10 AM »
We need some of that stuff for a certain ham's (promised) billboard.
Let us know what you find.
« Reply #4 on: September 24, 2017, 09:22:55 AM »
I think that Cheese Glue would work good in this application, give it a try.
K2OWK
« Reply #5 on: September 24, 2017, 04:54:57 PM »
Gliptol
73s
K2OWK
WZ7U
« Reply #6 on: September 24, 2017, 08:31:31 PM »
As long as it's the winter blend....
« Reply #7 on: September 24, 2017, 09:18:49 PM »
As someone here on eHam likes to say, "WOW!"
I've wound many air coils for antenna tuners and transmitters on pieces of Plexiglas and either ran the wire through holes drilled in the Plexiglas or simply used model airplane glue to hold the windings in notches filed into the edge of the Plexiglas.
I suppose this is what is meant by "ignorance being bliss."
W4AMP
« Reply #8 on: October 27, 2017, 03:07:22 AM »
AA4HA
« Reply #9 on: October 27, 2017, 06:48:13 AM »
Hot-melt is pretty common in tacking down coils to forms, I have also used it when making baluns.
Ms. Tisha Hayes, AA4HA
Lookout Mountain, Alabama
K4JJL
« Reply #10 on: October 27, 2017, 08:26:27 AM »
KAPT4560
« Reply #11 on: October 27, 2017, 02:55:54 PM »
 I looked up Q-dope and found this forum:
http://www.redwaveradio.com/5_1afd3a8e8ab985c4_1.htm
 There are more dope links to be found at the bottom of the page.
 I have used a coarse lathe feed setting to cut a groove into a plastic tube for a coil form. I also bend air-core coil windings at work to tune them. They are rigid enough to hold position through the vibration and temperature tests that come afterwards.
 A red varnish is dabbed onto them to both hold the coil windings and also to indicate to further radio build technicians that the tuning step was completed.
