Author Topic: Antenna Analyzer with STM32F7 (homebrew) from EU1KY  (Read 30164 times)
DH1AKF
« on: December 22, 2017, 02:32:26 AM »
Hello,
after successful building this famous analyzer, I want to announce it here.
Please have a look into the gallery:
https://bitbucket.org/kuchura/eu1ky_aa_v3/wiki/Gallery
Some landmarks:
- frequency range: 500 kHz  ..  450 MHz
- uses a touch screen (STM32F7 Discovery)
- calculates real and complex antenna impedance
- shows the Smith- diagram
-calculates the matching values for LC- adaption
- all software is open source.
DH1AKF
« Reply #1 on: January 01, 2018, 02:30:56 AM »
A Happy New Year to all visitors!
Here a picture of the "Measurement" menu:
A little article about my modifications you can find here:
http://www.wkiefer.de/x28/EU1KY_AA.htm
DH1AKF
« Reply #2 on: January 22, 2018, 02:19:31 AM »
A new design was created by help of 15 russian beta- testers:
The source code can be found at:
https://bitbucket.org/kuchura/eu1ky_aa_v3/branches/
DH1AKF
« Reply #3 on: April 20, 2018, 08:39:47 AM »
News from my Analyzer project: (EU1KY- AA450)
- frequency range exceeded, now from 100 kc to 600 Mc with the same hardware
- separate tuning window with sound and big progress bar for use in open air
- shows R and X values for the serial or parallel model, calculates resulting L and C
DH1AKF
« Reply #4 on: May 06, 2018, 11:43:21 AM »
New results of my development:
Outdoor- mode for SWR- optimisation:
"Find Frequency scan mode":
Simple spectrum analyzer:
You have more ideas? Please reply!
« Last Edit: May 06, 2018, 11:45:38 AM by DH1AKF » Logged
DH1AKF
« Reply #5 on: May 17, 2018, 04:18:34 AM »
Now are available:
- Russian Manual http://www.cqham.ru/forum/attachment.php?attachmentid=289144&d=1526543660 from LY2BOK
- English Manual  http://www.cqham.ru/forum/attachment.php?attachmentid=289133&d=1526519722 from VK5COR
DH1AKF
« Reply #6 on: June 11, 2018, 09:48:28 AM »
An idea of a different kind: It would be awesome if someone would find a buried treasure with the AA EU1KY! As a search coil a magnetic loop for 300 kHz, adapted to 50 ohms, and then you can start the search ...
Menu TUNE SWR // Sound, (to hear something)
Just an idea ...
K9AQ
« Reply #7 on: June 16, 2018, 06:32:31 AM »
I have purchased the analyzer and can't wait to get it!  I like the changes that you made to the software.  I will play around with it using the software it comes with, but then would like to install your modified software.
Thanks
Don
K9AQ
K9AQ
« Reply #8 on: June 25, 2018, 06:00:40 AM »
I have received my Eu1KY analyzer and have been testing it with the installed firmware.  I appreciate the enhancements that you have made and would like to install your software.  Do you have instructions on how to install your software to the STM32F7 board?
Don
K9AQ
DH1AKF
« Reply #9 on: June 25, 2018, 06:55:54 AM »
Firmware update
Programming is done with the STM32 ST-LINK Utility from ST Microelectronics at the ST-Link connector. (USB mini plug)
https://www.st.com/en/development-tools/stsw-link004.html
 Target> Connect: connect to the device
 File> Open File ...: load firmware in binary form
 Target> Program & Verify: program and verify
The latest version of the extended firmware can be found here:
http://www.wkiefer.de/x28/test/F7Discovery.bin
If you have more questions, please ask!
73, Wolfgang
K9AQ
« Reply #10 on: June 25, 2018, 11:35:24 AM »
Thanks!
K9AQ
« Reply #11 on: June 25, 2018, 11:41:30 AM »
Wolfgang,
I bought mine assembled, tested and calibrated.  After I install you firmware will I have to recalibrate it?
Don
K9AQ
DH1AKF
« Reply #12 on: June 25, 2018, 12:11:11 PM »
Yes, because the edge frequencies and the structure of some files is changed.
DH1AKF
« Reply #13 on: July 04, 2018, 12:40:28 AM »
Now I found a description, how to make the OSL- calibration resistors themselves:
https://forum.nvra.net/viewtopic.php?f=79&t=70
KD2PTC
« Reply #14 on: August 28, 2018, 01:22:35 PM »
I just finished building my analyzer and am having a problem so I wondered if anyone can comment on the following:
    When I try to do the HW Calibration. It gets up to 91% and then a message appears in the top left of the screen that says "No Signal. SYSTEM HALTED". I rebooted the system and tried again and it failed the same way.
    When I look at the DSP window, the magnitudes are about 1991 and 2093.  The instructions say it should be 1200-1600.  Are my values too high and too different from each other?
The main menu screen says I am running 'mod DH1AFK, Build 2018-08-10 19:58 UT'
Any help would be greatly appreciated. Thanks.
Karl
