Author Topic: IC-9100 & WSJT-X FT8 No Output Power  (Read 2517 times)
WB5BUL
« on: March 24, 2018, 08:26:08 PM »
I have owned my ICOM IC-9100 for just over a month and up until now had great success with FT8 (250+ contacts).  Now the program receives fine but there is no output power.  The rig changes to transmit when I hit the tune button or click on a CQ call but there is no output power.  I just discovered now there is no output power when I switch to SSB and try two different mics.  CW works fine.  Any help or suggestions will be greatly appreciated.
« Reply #1 on: March 26, 2018, 07:23:08 PM »
Provided the two mics are good, it is time to break out the schematic, the parts layout diagram, and an audio tracer and start tracking down where the audio dies inside th IC9100.  You make no mention of how the audio gets into the 9100, but you know, so start audio tracing.
ARRL Missouri Technical Specialist
AA2UK
« Reply #2 on: March 27, 2018, 04:06:07 AM »
If all else fails try a master reset. Is the rig under warranty?
Bill, AA2UK
