Author Topic: kx2 power on edit it on banner  (Read 1041 times)
N4MJG
« on: May 11, 2018, 05:16:12 PM »
hi
I have  kx2 I wanted to do put my call on banner my setting are  com nothing is happen it plug in to the pc and to the radio no help ! what am I doing wrong I'm new to this new radio april 12 2018 I'm ready to gave up !
Jackie
N4MJG
K3GM
« Reply #1 on: May 11, 2018, 05:46:35 PM »
Jackie, in the utility, you must select the correct COM Port number, and match the com speed to the setting on the KX2.  First set the com speed to match the setting of the KX2.  I forget what the default speed is set to.  It's in the manual.  Once the speed is set, you can try each port number in the utility until it connects.  Alternately, when you plug the transfer cable into the USB port on the PC, check the hardware settings on the PC, and it will tell you what com port it is using.  Then set the utility to the same number.
Ultimately ....It's just a banner.
« Last Edit: May 11, 2018, 05:59:28 PM by K3GM » Logged
N4MJG
« Reply #2 on: May 11, 2018, 07:51:52 PM »
It's on com port 4 and 38400
N4MJG
« Last Edit: May 11, 2018, 07:53:55 PM by N4MJG » Logged
