Author Topic: Harris RF Communications RF-2200 Schematic  (Read 979 times)
K4ABL
« on: August 14, 2018, 03:50:37 PM »
I am looking for a copy of a schematic for a Harris RF-2200. A manual copy would be good too. Anyone have one of these transceivers and use it on the Ham bands? Huh
Chuck
K4ABL
W9GB
« Reply #1 on: August 14, 2018, 04:48:40 PM »
Chuck,
Do you mean the Harris RF-3200 ?
Introduced in 1989, the Harris RF-3200 transceiver operates in the 1.6 to 30 MHz range.
It can also be tuned to receive down to 500 KHz for monitoring Navtex broadcasts.
Standard RF output is 125 watts.
With the addition of an optional solid-state linear power amplifier, the unit can provide 1 kw power output.
An important technical advance is the use of a single multiplexed coaxial cable to the antenna coupler, which eliminates the requirement for the usual multi-conductor control cable.
This coax supplies electrical power to the coupler and also provides two-way digital communication between the coupler and transceiver.
eHam.net Reviews of Harris RF-3200
https://www.eham.net/reviews/detail/4213
The RF-3200 has appeared via Surplus auctions and outlets over past decade.
https://www.govdeals.com/index.cfm?fa=Main.Item&itemid=725&acctid=495
W2HX document repository on Harris RF-3200
http://www.w2hx.com/x/Harris/RF-3200/
Search YouTube videos for Harris RF-3200 from 2010 - 2012 period,
for operational videos.
« Last Edit: August 14, 2018, 05:04:09 PM by W9GB » Logged
K4ABL
« Reply #2 on: August 15, 2018, 05:13:37 PM »
No, it is a Harris RF-2200 transceiver. It was manufactured around 1974 and was used for various purposes including boat/marine communications. It is working but I need to learn more about it.
THANKS
