Pages: Prev 1 2 [3] 4 5 Next   Go Down
Author Topic: air vs oil dummy load ?  (Read 4358 times)
KC4ZGP
« Reply #30 on: August 27, 2018, 05:45:57 AM »
Herr Booty Monster,
Alrighty. Welcome to the hobby. Anyone can learn anything. Get that license man!
An MFJ-259B. Alrighty. I use a RigExperts AA-30. Both great antenna tools.
Vector 4000. OK. Lengthen or shorten elements for other bands. Your MFJ-259B will guide you.
Palomar 300A amplifier. OK. Legal to use it if licensed to use it.
I have an idea. Build a delta loop or dipole for 27.185MHz, middle of the citizen's band. Examine differences via the
MFJ-259B. You'll have to 'dig' in the books to build either antenna.
That's ham radio. And like I said, get that license man!
Kraus
KC4ZGP
« Reply #31 on: August 27, 2018, 05:58:46 AM »
probably a stupid question , but ......
could a mfj-264 be submerged in a gallon of oil for longer duty cycle ?
Yes you can. The 'paint can' dummy loads are an MFJ-264 resistor element submerged in oil. Pennzoil
10W-30 or thicker will work. The oil just dissipates heat.
Have fun experimenting.
Kraus
« Reply #32 on: August 27, 2018, 07:46:19 AM »
I would use straight weight SA rated 10w or 20w20 non detergent oil if you use motor oil
KE6EE
« Reply #33 on: August 27, 2018, 08:14:00 AM »
Back in the day it was a club fundraiser to make "1kW" saltwater loads out of plastic gallon pickle jars from a restaurant, and the test criteria was full keydown from a TL-922 for 10 minutes which it easily handled.
Salt water dummy loads remind me of my novice days when all I had was a light bulb dummy load. I had a long CW QSO with a ham in Germany using that "dummy load". It was a great grade school learning experience.
Very amusing!
Using a metal container and some peanut or canola oil, a good fundraiser event might be to see who could fry a donut with a "dummy" deep fryer load.
I remember the light bulb dummy loads I used. Very exciting to see the
bulb brighten as I tuned the pi-network of my 807-powered rig. Such a device really should be called an "enlightened dummy load."
K6BRN
« Reply #34 on: August 27, 2018, 08:32:42 AM »
Mark:
So, you really think standing next to an open bucket of conductive salt water while running a KW of RF through it is a wise move?  One that could spill at a moment's notice, so that you are standing  in it's conductive contents in the middle of an electical wiring jungle and ever-present RF voltages   Or whose container could shatter if you were to use glass as the the pretty ignorant person in the link you supplied did?  And you think the impedance will be stable and well controlled?  And you don't think that salt and water reacts with metal to degrade it (you don't have a boat, do you?)
Are you applying for the 2018 Darwin award?
No - it's NOT a good approach and that's why you will NEVER see this done commercially, or even in OTC amateur equipment.  The potential liability is sky high and the performance will be predictably poor.  This is just a BAD idea with strong safety risks, which is why I'm just a little excited about it.
You should have a disclaimer:  "Don't try this at home" just to protect yourself from the liability of some hapless elf on this forum repeating the experiment and being electrocuted.
As I said... as a demo, hey, wow, interesting.  And stand back, please.  It's like Glenn's light bulb...  "Wow!  See it glow!".  Now put it away before you hurt someone and buy or build the real thing (using a safe and stable approach - NOT a coax dipped into water bucket or glass jar full of salt water).
Be smart.  Stay safe.
Brian - K6BRN
« Reply #35 on: August 27, 2018, 08:39:52 AM »
I remember when I built my Heathkit HW16 about 49 years ago. It recommended using a light bulb (75 watt I think) as a dummy load when aligning transmitter.
« Reply #36 on: August 27, 2018, 09:08:56 AM »
JX:  Right you are!  Have you noticed a tendency to overthink everything these days?  I fell into this trap several years ago when I wanted a circuit to perform a function which I now forget....spent hours designing a solid state circuit and before I could put it together I realized what I wanted could be done with a .....wait for it ..... a simple relay!
I said to myself. "Myself, what the hell's wrong with you?  KISS:  Keep It Simple Stupid!
In this case, experiment if you wish then publish your findings.  Don't ask, "what if?"
« Reply #37 on: August 27, 2018, 09:31:59 AM »
It's not open, it has a lid.  That's where the connector and conductors are mounted.
Not with a lid on it.  Never made one with a bucket but the jars are designed to hold liquid for their original contents and seal quite well.
Hasn't happened in a few decades so far.  Not impossible though I guess.  If you're accident prone, use plastic.
Yes, very much so.   The solution isn't terribly sensitive as far a concentration and as long as nothing evaporates (see "lid" above) then it just stays that way.  For years.
I have observed that the copper turns dark (like a penny) but that's about it.  And if you use steel screws and nuts on the SO-239 they will rust eventually.  Nylon or stainless hardware takes care of that.  Or just use an extra large blob of silicone on the connector.
I didn't bother applying after I found out you have to do something much worse than running with scissors.
Never said it was perfect.  But for the time, money and complexity it sure works pretty good.
No more risky than anything else you do with electricity.  Common sense and basic awareness will take you a long way.  As a product you have to design for the lowest common denominator, which is why you have to sell hair dryers with a label that shows a bathtub with a circle and slash over it, because there's someone out there that will try it.  But, this isn't a product.  Sorry if this is an affront to your sensibilities, feel free to trumpet my lack of caring and idiocy for suggesting such folly.  Meanwhile my saltwater loads on the shelf are a great curiosity and topic of discussion with visitors of my shack and come in handy for testing from time to time when I'm not busy running with scissors.
« Reply #38 on: August 27, 2018, 09:40:32 AM »
ratio of water to input power is directly proportional so 1 gallon at 1 kW would also boil in about the same amount of time.
As an empircal data point, there's a graph on my site that shows actual temperature vs 100W input with ~22oz of water which takes into account some degree of convection/conduction to ambient.  Haven't done the calculation but I wonder if that correlates to your 1gal/1kW conclusion.  When we built and tested the 1 gallon ones I'm not sure if it was exactly one gallon, might have been more (whatever the freebie restaurant pickle jars were) and I recall they never boiled after 10 minutes.
K6BRN
« Reply #39 on: August 27, 2018, 11:34:10 AM »
Mark:
I can't fix stupid.  Only you can do that.  It's your life.  But please do NOT try convince some poor hapless fool that a multi-gallon salt water dummy load built out of a plastic bucket (ummm... with a lid - GREAT!) from Home Depot is in any way safe or wise around the "shack".
And a flimsy plastic bucket of several gallons of electrified salt water next to energized RF electronics and AC lines IS more dangerous than running with scissors.  But than, a Darwin candidate wouldn't know that.
On a qualitive note, a person who had made good choices in life would probably never need or consider building what is essentially a portable electric chair into their operating position.  They could afford the hundred bucks  +/- needed to buy or build a safe one.  Thomas Edison pretty much proved what could happen over a century ago with AC and water.  You really do not have to repeat the experiment.
As a sanity test, try proposing your approach at work and bring in an OSHA rep to give it a "thumbs-up",  They could probably use the comic relief.
Once again - SAFETY OVER STUPIDITY.
Best Regards,
Brian - K6BRN
K6JH
« Reply #40 on: August 27, 2018, 12:58:47 PM »
Wow! An oil thread on e-Ham!
I would go for Mobil-1 synthetic myself.  Cheesy
Jim K6JH
W9CN
« Reply #41 on: August 27, 2018, 01:32:48 PM »
Mobile 1 rocks.  Especially if you live someplace where it gets to negative temps in the winter.  It doesn't turn to molasses at 10F below.  I have four vehicles with over 120K on them all running Mobile 1.
« Reply #42 on: August 27, 2018, 01:37:03 PM »
My first experience with a dummy load and wattmeter was with the B&W 334A that was used at National Radio almost 10 years after I was licensed, built many Heathkit rigs for myself and others plus a couple of KW amps while still in HS. Lightbulbs and OTA were the only methods available to the po boys back then.
« Reply #43 on: August 27, 2018, 01:48:03 PM »
Looooong before Mobil 1...not Mobile, the cold weather formula was a quart or two of kerosene or diesel added to the non detergent 30W in the crankcase; this was also mentioned in owners manuals.
It was always fun getting a 6V vehicle started at -20F or so and especially the always gummed up flathead Ford V-8's. When I moved up to MA/NH a 8V tractor battery and adjustable regulator were a big help. Kind of rough on headlights but they were only $.10-to .25 in a junkyard.
In the early 2000's I used a 12V battery to start a 54 Ford F-350 with a V8 Y Block and a transfer switch to 6V for driving.
W9CN
« Reply #44 on: August 27, 2018, 02:34:02 PM »
Autocorrect strikes again with the Mobil/Mobile.
Pages: Prev 1 2 [3] 4 5 Next   Go Up
