Author Topic: TS-520 with Remote VFO - Low Signal Receive  (Read 701 times)
N9CM
« on: August 30, 2018, 02:51:42 PM »
When hooked up to the remote VFO VFO-520, the radios receive is grossly attenuated. Ideas?
Appears to be the radio.  When same VFO is hooked to 820 works properly but same remote VFO on the 520, and no received signals.
« Last Edit: August 30, 2018, 02:55:50 PM by W0XX » Logged
N9CM
« Reply #1 on: August 30, 2018, 05:01:44 PM »
Found problem.  Someone was inside the radio and made some great solder jobs in there..VFO signal connection off the jack/receptacle inside the radio...
