Author Topic: Any ideas what this is for?  (Read 648 times)
K5TED
« on: September 10, 2018, 11:28:07 AM »
KC4ZGP
« Reply #1 on: September 10, 2018, 11:51:30 AM »
What in the heck?
Where ever did you find that picture?
A yagi pointed to the sky? A beacon? Hmmm....
Kraus
« Reply #2 on: September 10, 2018, 12:00:29 PM »
It is likely a remote site that they fly over at altitude and collect data from time to time. Could possibly be a satellite up-link too.
N8YX
« Reply #3 on: September 10, 2018, 12:46:22 PM »
Look in the background.
Those are weather data instruments.
K7MEM
« Reply #4 on: September 10, 2018, 02:34:53 PM »
What in the heck?
I note an offset in the elements along the boom, so it is more likely to be a log-periodic. And, judging from the thickness of the elements, the whole array is very wide banded.
Martin - K7MEM
http://www.k7mem.com
« Reply #5 on: September 10, 2018, 03:54:02 PM »
looks to me like an ILS Marker Beacon Antenna, but without a scale, it's hard to guess the frequency. Certainly doesn't look big enough for an outer marker which would be around 75 MHz. Inner markers are higher.
K3GM
« Reply #6 on: September 10, 2018, 04:46:13 PM »
Peter is correct.  It's a marker beacon antenna used in conjunction with the glide slope to an airport.  A single LPDA is usually used for an inner marker.  Dual antennas are often seen at an outer marker location.  The difference between the two is the the fly-thru time is shorter with two antennas than with one. Transmit frequency is around 75 MHz.
« Last Edit: September 10, 2018, 05:01:51 PM by K3GM » Logged
KC4ZGP
« Reply #7 on: September 10, 2018, 04:56:24 PM »
I was correct first. I suggested a beacon but I'm too mature to point  it out.
Oh gawd Kraus!
