Pages: Prev 1 2 [3]   Go Down
Author Topic: QRP?? Maybe not much longer.  (Read 2617 times)
K3UIM
« Reply #30 on: December 23, 2018, 03:26:30 PM »
I couldn't find a cable ID number on the "link" to the SWR bridge, so I cut about 18 inches off of the feed line, gave both lines a new connector and tried for SWR. Same result so the "link" must have matched impedance.
Charlie, K3UIM
Where you are: I was!
Where I am: You will be!
So be nice to us old fogies!!
K3UIM
« Reply #31 on: December 25, 2018, 06:54:06 PM »
I might be reading the SWR scale wrong.
Above the top scale it starts at 1.
4 small lines and then 1.5,
4 small lines and then 2,
1 small line half way to 3,
Then a red thick line to "SET."
Under the top scale line it's 1.
Under the 1.5 it's 4,
Under the 2 it's 11,
Under the 3 it's 25,
Then the red thick line goes to the end. ("SET")
Am I reading the SWR correctly? (I may have to invest in a two needle unit.) Hi.
Charlie, K3UIM
K3UIM
« Reply #32 on: December 28, 2018, 10:40:55 AM »
Using a 2 meter unit I get the same results. I am stumped!
Any ideas??
Charlie, K3UIM
Pages: Prev 1 2 [3]   Go Up
