Author Topic: Heathkit SB-101 Finals  (Read 1474 times)
N0XAX
« on: December 14, 2018, 11:25:00 PM »
I am restoring a Heathkit SB-101 transceiver with bad 6146A tubes. My question to you elmers is, can I put 6146W tubes in this radio, or does it have to have 6146A tubes? I know I have to neutralize the new tubes after I install them in he radio. I know some radios like the Kenwood hybrids had to have certain tubes. I was going to put 6293 tubes in it, but I found (2) 6146W NOS tubes at a really good price. I'm quite sure that there are some operators on here that are familiar with the SB-101. Any input greatly appreciated!
W5RKL
« Reply #1 on: December 15, 2018, 05:47:14 AM »
I  recommend 6146As. You can find them at
http://vacuumtubes.net/
for $22.
The final amplifier is the same in the HW-100/101, SB-400/401, and the SB-100/101/102 set of transceivers/transmitters.
They all operate in Class AB1.
The 6146As will last a long time providing the operator does not abuse them by trying to push for higher power output.
When properly tuned, the above transmitters will produce approximately 100 watts output into a 50 ohm load.
Switching to a "B or "W" or pulse version of 6146 Beam Power tube will not result in an increase in power output.
Mike W5RKL
www.w5rkl.com
RMC(SW) USN RET
KC1BMD
« Reply #2 on: December 15, 2018, 08:21:39 AM »
See this well-respected reference:
The 6146 Family of Tubes
by Glen E. Zook, K9STH Copyright 2002 by author
KD0REQ
« Reply #3 on: December 15, 2018, 08:31:15 AM »
best conclusion I've come to is, depends. most Heathkits should have enough latitude in the neutralization to make them work. a few folks have had trouble.  since you have the tubes on hand, give it a try. all you've got to lose is a few hours of fooling around if they don't stay stable.
WA5VGO
« Reply #4 on: December 15, 2018, 11:25:52 AM »
Used them all in my HW-10 and SB-100. No problem with any of them.
KX4OM
« Reply #5 on: December 15, 2018, 03:11:42 PM »
GE 6146Ws did not neutralize in my HW-101. The rig came to me several years ago with one 6146 and one 6146A. After the 6146W trial, I put GE 6146B tubes from RF Parts in it, and it still works fine. The 6146W tubes were NOS new from the FAA directly to me in 1979. I used them briefly, about 3 months in my SB-100 before I sold it (sans the 6146W finals.) I suppose I could try the 6146Ws in my Tempo 2020, which has the original Toshiba 6146B tubes in it. The 6146x tubes and Heathkit continue to be a mystery to me. Glen's article on the family provides insight, especially Heathkit's stock of relabeled tubes from the vendor after the 6146A stock ran out.
Ted, KX4OM
« Last Edit: December 15, 2018, 03:22:44 PM by KX4OM » Logged
N0XAX
« Reply #6 on: December 15, 2018, 04:52:07 PM »
Thank you all for your replies. I'm going to try the 6146W tubes and see what happens. If they won't neutralize correctly, then I will put 6146A tubes back in it. FYI: The RCA tubes in this have a date code of 9-67! These are probably the original tubes in this radio? The grids are bad in both tubes. Also, the operator that had this radio knew tubes! 75% of the tubes are original Mullard tubes and they all check better than 90% or better! I have a Sencore Continental tube checker that also checks mutual conductance as well on certain tubes. Thank you again, and I will also check out those links. I'll let you all now how it turns out. Oh, also, I have to find an rf probe for my heathkit vtvm! I saw where this is needed in the neutralization procedure! So it's off to find an rf probe. 73
KD0REQ
« Reply #7 on: December 15, 2018, 06:17:16 PM »
Make the probe, diagrams clutter the web.
KB2WVO
« Reply #8 on: December 16, 2018, 11:58:45 AM »
if u have a Oscope. there is a video on neutralization with a Oscope.. YOU MUST REMOVE THE HV FROM TUBES...
its on utubers. i did it on the sb110 i have worked great. check for sb110 on utubers. iam guessing bein same tubes and probley same final section probley close..
found vid for ya..
https://youtu.be/5n-BdFx2HT8
« Last Edit: December 16, 2018, 12:01:22 PM by KB2WVO » Logged
AD4U
« Reply #9 on: December 16, 2018, 04:34:42 PM »
Why not just buy a new pair of 6146A tubes and be done with it. I built a SB 101 in 1970. This was my first "real" rig. I used it daily until around 1985 when I bought a Drake station. I still have and still use my SB 101 and it still uses the original 6146A tubes that came with the rig and they still give 100+ watts in 2018. The purpose of my post is to say a pair of NOS 6146A tubes should run DECADES if operated properly.
Dick AD4U
« Reply #10 on: December 19, 2018, 03:06:49 AM »
NEVER remove the plate supply to tetrodes WITHOUT removing the screen grid supply. If you do, all the current goes to the screen and over-dissipates it.
K1DA
« Reply #11 on: December 30, 2018, 11:46:20 AM »
Read Glen Zook's work as previously mentioned.   6146w tubes could be EITHER a standard 6146 OR a 6146B which requires different neutralization.
