Author Topic: EZ Guide to Understanding APRS Raw Packets?  (Read 760 times)
N4SRN
« on: January 28, 2019, 03:31:53 PM »
I’m looking for an EZ Guide to understanding APRS Raw Packets such as seen on APRS.FI raw display options. “EZ” as a write up addressing such a topic rather than referring me to the specification. A Primer, so to speak, for the less technical folks not inclined to get a EE/ComSci double major.  ;-)
Bret/N4SRN
Bret/N4SRN
Bedford, NH  USA
W4KYR
« Reply #1 on: January 29, 2019, 05:30:44 AM »
Bret/N4SRN
Let me add another question to go with your question. Is it possible use "Wireshark" to analyze APRS and Packet Radio Packets? If so, how?
VE7KNL
« Reply #2 on: January 29, 2019, 05:37:50 AM »
This might help
http://www.aprs.net/vm/DOS/PROTOCOL.HTM
WD9EWK
« Reply #3 on: January 29, 2019, 08:47:37 AM »
In addition to this, the aprs.fi site provides a way to decode the raw packets. When you are looking at the raw packets for a station, you will see a drop-down menu that should have "Normal". Change that to "Decoded", and then you see both the raw packet and a breakdown of most of the data in the packet. Here's an example showing position packets and a message...
73!
Patrick WD9EWK/VA7EWK
http://www.wd9ewk.net/ - Twitter: @WD9EWK or http://twitter.com/WD9EWK
N4SRN
« Reply #4 on: January 29, 2019, 09:38:14 AM »
Excellent stuff y’all - thanks!
Bret/N4SRN
Bedford, NH  USA
KB3VWG
« Reply #5 on: January 30, 2019, 07:09:09 AM »
Yes!
I simply ran Wireshark on the interface that was speaking AX.25. You can also collect pcap files via tcpdump to be read in Wireshark.
Also, a guide on the raw packets: https://www.tapr.org/pub_ax25.html - that is the specification of the protocol.
KB3VWG
W4KYR
« Reply #6 on: January 30, 2019, 08:01:36 AM »
Yes!
KB3VWG
Thanks
