Pages: Prev 1 2 [3]   Go Down
Author Topic: Cost of Building an HF Amplifier?  (Read 3711 times)
KX4QP
« Reply #30 on: March 04, 2019, 04:15:12 PM »
One thing about "your price range" -- I built a telescope around twenty years ago.  I spent about the same money it would have cost to buy a similar instrument, but a) I never spent more than about $50 at one time, and b) I got an instrument that performed roughly as well as a slightly larger, much more expensive commercial scope.  Your "price range" can be much more flexible when you don't need all the money at once.
MM0IMC
« Reply #31 on: August 23, 2019, 07:34:22 AM »
Would starting off small scale with GI7B's, then progressing to a GS35B working, once I've got the confidence?
« Reply #32 on: August 23, 2019, 07:48:42 AM »
My guess is you want to start of first with the high voltage power supply, and then get tubes that will best use what you built.
There was a time where tubes were the hard part, and the HV transformer was the easy part, but I believe the situation is reversed for you now.
I could be wrong, maybe you live next to a benefactor with a collection of HV transformers he needs to find a home for, but many of those collections in the USA are now gone.
« Reply #33 on: August 23, 2019, 08:26:45 AM »
I certainly would not recommend that tube unless you are going for bottom cost and signal quality.
Here is an article from one of the best known real experts.
https://owenduffy.net/tx/GI7B/index.htm
Not mentioned is that the GI7B is a low mu tube and is designed for pulse type and industrial applications. Its mu is very low compared to all the well known triodes used for GG linears.
https://frank.pocnet.net/sheets/018/g/GI7B.pdf
Think of it as similar to the 5867/TB3-750 which are available dirt cheap but no ham amp uses them as a sub for a 3-400/500Z. It is a great tube for Class C AM Grin
https://frank.pocnet.net/sheets/089/t/TB3-750.pdf
K6BSU
« Reply #34 on: August 23, 2019, 10:20:24 AM »
I've built 3 amplifiers.  A 3-500Z, one with three 811's and one solid state.  I only did it because I didn't find a commercial amp that suited my aesthetic requirements.  For instance, my 811 amp has the three tubes just behind the front panel, which has a large cutout with glass and brass screen.  I like to watch the tubes glowing!
MM0IMC
« Reply #35 on: August 23, 2019, 11:53:25 AM »
Gotta love that glow from a glass valve (tube).  Wink
Pages: Prev 1 2 [3]   Go Up
