Pages: Prev 1 2 [3]   Go Down
Author Topic: Icom 9700  (Read 5939 times)
AA2UK
« Reply #30 on: May 25, 2019, 08:42:10 AM »
Has it been determined by anyone yet, whether the IC-9700's drift is due to TCXO thermal cycling, or a voltage regulation problem?  (or even some combination of these)
Potential fixes for either of these causes could be very different from each other.
73, Ed
I asked the same Q earlier. But I'm not opening mine at this point.
Bill AA2UK
N4UE
« Reply #31 on: June 05, 2019, 03:21:59 PM »
Hi. Belonging to the 9700.io Group, I have seen that Icom Europe has made a firmware change to eliminate the 'drift' issue.
However, we'll have to wait for Icom Japan to make it official.
I LOVE my 9700 and since I don't do EME or FT8, my radio has performed orders of magnitude over my 271A (with optional Mutek preamp).
Lots of guys on the 9700.io Group have reported making MANY FT8 contacts on 70 CM with NO problems.
So all the 9700 haters should move to a different radio, they can't afford. ha ha
ron
N4UE
If you're not the lead sled dog, the view never changes......
WB8LBZ
« Reply #32 on: June 05, 2019, 09:38:05 PM »
Something else that is broke, how about all of the software titles that don't support the 9700?
N3FJP - Nope
WSJT - Nope
FLDIGI - Nope
JS8CALL - Nope
The 9700 is a great rag chew rig. Some of us would like to do more.
73, Larry  WB8LBZ
El Paso, TX
SN:12XX
AA2UK
« Reply #33 on: June 06, 2019, 06:21:31 AM »
The 9700 will be fully WSJTX supported in the next mid-July general release v2.1.0 I got this from Joe Taylor himself. In the mean time you can run WSJTX using 2.0.1rc5 not 2.0.1.
Bill AA2UK
AA2UK
« Reply #34 on: June 06, 2019, 08:55:05 AM »
Actually if you want to marry up WSJTX with the IC-9700 v2.1.0rc7 has just become available. It can be found here.
https://physics.princeton.edu/pulsar/k1jt/wsjtx.html
Bill, AA2UK
WB8LBZ
« Reply #35 on: June 06, 2019, 03:53:13 PM »
Thanks Bill. I have downloaded it and will be testing.
73, Larry  WB8LBZ
El Paso, TX
VE6MB
« Reply #36 on: June 06, 2019, 07:15:18 PM »
The much anticipated firmware release 1.10 was issued.....
Valentino, VE6MB
Firmware V1.10 for the IC-9700 was released today (7 June 2019 in Japan).
http://www.icom.co.jp/world/support/download/firm/IC-9700/1_10/
Release Notes:
Changes from Version 1.06
    "Sync to REF IN" function is added for the reference frequency adjustment.
    "UDP Hole Punch" function is added to the DV Gateway function.
    "Home CH Beep" function is added.
    An indication showing Shifted Digital Twin PBT is added in the filter icon.
    SCAN key action is changed.
    A file format to save the settings readable with older version firmware is added.
    The CI-V commands 25 and 26 work correctly.
In addition< the CS-9700 software has been updated.
http://www.icom.co.jp/world/support/download/firm/IC-9700/CS-9700_1_10/
Release Notes:
Changes from Version 1.01
    The setting items below are added to support IC-9700 firmware version 1.10.
        "Home CH" (Band Setting, DR Mode Setting).
        "Home CH Beep" (Common Setting > Beep).
        "Sync to REF IN" (Common Setting > REF Adjust).
        "UDP Hole Punch" (DV Gateway > Internal Gateway Set).
WB8LBZ
« Reply #37 on: June 06, 2019, 08:27:28 PM »
Thanks for the links Valentino, both upgrades went well.
73, Larry  WB8LBZ
El Paso, TX
G4AON
« Reply #38 on: June 07, 2019, 03:03:42 AM »
Does the “sync to ref in” now mean it will lock to an external rubidium or GPS 10 MHz standard to operate in the same way that test equipment does? ie no more drift...
73 Dave
VE6MB
« Reply #39 on: June 07, 2019, 06:04:18 AM »
It would appear so. I am using a Leo Bodnar GPSDO tied to the IC-9700 and can see (from a cold start) constant ongoing adjustment the LO REF setting......after the radio has been on a while it settles down and there is very little adjustment change over time.
 I am reading discussion on the IC-9700 email list as people are trying out this firmware release. Early indication is that there is a marked improvement in the whole drift concern; but ongoing formal testing is being done to quantify it; particularly on 23cm (1.2Ghz).
Valentino, VE6MB
VE6MB
« Reply #40 on: June 07, 2019, 07:08:51 AM »
Bill, AA2UK
I wasn't aware that WSJT-X had been updated for the IC-9700.......however, I've been successfully using it prior to this by changing the CI-V interface address in the IC-9700, to that of the IC-7300.....effectively making the software think it's talking to the IC-7300......it works perfectly. Then, I merely removed all band info and references to HF bands leaving 2m, 70cm, 1.2Ghz as available band options.
Valentino, VE6MB
K3GM
« Reply #41 on: June 10, 2019, 05:43:41 PM »
73 Dave
My understanding is that it's not phase locked, but more of a constant "compare and correct".  In talking to my friend though, he suggested this seemingly inferior method of frequency stability might be a good thing because if the 10 MHz reference has phase noise on it and an otherwise clean oscillator is phase locked to it, the phase noise will be imposed on the clean oscillator at least within the bandwidth of the PLL.
KD7RDZI2
« Reply #42 on: June 26, 2019, 11:42:49 AM »
ron
N4UE
Enjoy https://rsgb.org/main/blog/news/gb2rs/headlines/2019/06/14/iaru-addresses-2m-23cm-threats/
ha ha
« Last Edit: June 26, 2019, 11:58:49 AM by KD7RDZI2 » Logged
AA2UK
« Reply #43 on: July 02, 2019, 09:19:16 AM »
ron
N4UE
ha ha
This is really funny information.... What does it have to do with the ICOM IC-9700 performance?
Bill AA2UK
Pages: Prev 1 2 [3]   Go Up
