Author Topic: CONNECTOR FOR A BIRD DUMMY LOAD  (Read 1381 times)
K0WRX
« on: February 24, 2019, 08:20:45 PM »
I have a 1000 watt Bird dummy load, model DA-173/GRM-10, and I am looking for the Male connector on the front of the unit.
If any one knows the connector type I would very much appreciate your response.
Pete, K0WRX
KE0ZU
« Reply #1 on: February 25, 2019, 04:07:58 AM »
Looks like a standard "N" connector.
Regards, Mike
https://mikeharrison.smugmug.com/
Pics and bold print are usually links.
W4OP
« Reply #2 on: February 25, 2019, 05:44:41 AM »
These are large flange  Quick Change connectors and available from Bird dealers. Considerably larger flange than standard type N. 1" versus 1.25"
https://www.rfparts.com/wattmeters-vswr/birdaccessories-qcconnectors.html
Dale W4OP
« Reply #3 on: February 25, 2019, 06:36:36 AM »
If you are putting together a collection of test equipment keep in mind that other Bird test equipment has the same easily swapped connector.
K0WRX
« Reply #4 on: February 25, 2019, 07:15:09 AM »
Thank you for your replies, and yet another problem solved for me as to where and how to find difficult parts.  I tried locating one at the Wheaton Hamfest last month but came up empty.  Everyone who reads and responds to these many requests for help/information are really contributing to the longevity of our hobby and equipment.  Thank you....Pete
« Reply #5 on: February 26, 2019, 04:11:54 AM »
The purpose of the Quick Change connector is to allow you to easily configure Bird test equipment to your preferred connector style.  You could swap everything out for BNCs or UHF connectors instead of the standard N connectors.
