Author Topic: How to interface HW-101 to SB-220 amp  (Read 742 times)
KD0ZGW
« on: March 24, 2019, 11:19:37 AM »
Recently got my HW-101 working well.  Used it for my weekly net check-in and got very nice signal and audio reports.
1st boat anchor for me.  Just scored a deal on an SB220 amp and would like to interface but as far as I can tell the HW-101 lacks a amp relay output.  The manual pic implies an amp relay output exists in the main connector on the back but doesn't show any detail.
what is required to make this interface work?
Thx to anyone taking the time to offer advice or links.
KD0ZGW
KD0REQ
« Reply #1 on: March 24, 2019, 11:55:01 AM »
details should be in either one of the manuals (and there are bootlegs all over the place if you don't have them or want to order from The New Heathkit.)  essentially, connect the ALC line, coax into the amp from the 101's antenna, and there is another phono jack on the back of the 101 that will key the amp. the 3-500 is an "instant on" tube, and the amp does the antenna switching, but I expect it takes a couple seconds to build HV and heat the cathode in the 220.  being a manual tuned tube amp, you're  going to have to key the 101 in CW to tune the 220 off frequency so you don't step on a QSO. no need to retune on freq from a few KHz off. unless you're loading into a floor lamp's cord.
W5RKL
« Reply #2 on: March 28, 2019, 03:35:48 AM »
Disconnect the power cable from the rear of the HW-101.
Remove the top and bottom covers and turn the HW-101
upside down, rear panel facing you.
Find the "BLACK" wire in pin "11" on the rear panel power connector.
Heat pin 11 and pull the BLACK wire from pin 11.
If the BLACK wire will not reach the center terminal of the SPARE
RCA socket, add a small length of BLACK wire to lengthen the wire.
Run BLACK heat shrink tubing over the connection then connect the
free end of the BLACK wire to the center terminal of the SPARE RCA
socket.
You now have a N.O. (Normally Open) "RELAY" connection you can
connect to a linear amplifier's "RELAY" socket. I've done this wiring
change to all 3 of my HW-101s and SB-100. I changed the socket
label from "SPARE" to "AMP RELAY".
The SB-220 has "120VDC" on it's "ANT" (RELAY) socket.
Mike W5RKL
www.w5rkl.com
RMC(SW) USN RET
KD0ZGW
« Reply #3 on: March 29, 2019, 08:29:01 AM »
Mike; thx for detailed advice.
KD0ZGW
