Author Topic: Kenwood TS830 slow warm up...  (Read 862 times)
AG4L
« on: March 29, 2019, 04:07:04 PM »
I have a kenwood TS830 that is slow to gain volume level.
When I first turn it on volume is very low.. After about 1-2 minutes. the volume
begins to increase. Im suspecting a falulty Cap.. somewhere. Which section should I
look at.
Thanks
Steve / AG4L
Nc
W8RLC
« Reply #1 on: March 29, 2019, 09:02:45 PM »
What troubleshooting have you done and what were the results? Have you taken any voltage measurements? Have you looked at the audio stage using a scope?
VA6JRC
« Reply #2 on: March 30, 2019, 08:53:15 AM »
A good starting point would be to monitor the DC voltages used by the Audio board. If you have a schematic of the AF unit, look at the upper right corner. TP6 is 9 volts. To the right of Q30 is 12.5 volts. To the right of Q34 is 14 volts. Watch what those voltages do in the first couple of minutes.
Cheers
VA6JRC
AG4L
« Reply #3 on: March 30, 2019, 02:17:05 PM »
Have not done and real trouble shooting as of yet.
Just wanting to know where to start.
Ill start with VA6JRC's suggestions..
Thanks
KB7TT
« Reply #4 on: April 01, 2019, 08:21:54 AM »
Good idea.  You may have something out of tolerance in the AVR board, check those voltages.
Gud luck, great radio,
N8YX
Posts: leet
« Reply #5 on: April 01, 2019, 11:07:59 AM »
What does the S meter do during this warm-up time?
VA6JRC
« Reply #6 on: April 02, 2019, 08:21:54 AM »
I'm not aware of any AVR board? I suggested he measure the DC voltages on the AF board.
