Author Topic: HW-101 rookie user question re tuning  (Read 463 times)
KD0ZGW
« on: April 02, 2019, 01:53:42 PM »
So I've learned how to tune it up and made a few contacts with good reports.
typical set up is HW-101 to manual tuner or resonant antenna.  So far for non-resonant I am using another rig to get the antenna tuned up before I switch to the Heathkit.
Question:  How do I know when a retune is warranted as I sweep across a band with the HW-101?
W3RU
« Reply #1 on: April 02, 2019, 02:15:43 PM »
Redip the plate at 35-50 watts (reduce the drive in Tune position) with a 10KHz frequency change, then repeak the preselector slightly for a peak in plate current.
You may run into SWR trouble on 75-80 meters, depending upon how far you move from the center frequency of the antenna.  Other bands should handle the larger difference.
Jack  W3RU
« Last Edit: April 02, 2019, 02:35:52 PM by W3RU » Logged
W5RKL
« Reply #2 on: April 02, 2019, 02:53:50 PM »
Mark,
If you change frequencies more than 15Mhz then I would recommend touching up the transmitter tuning.
If you move from the Phone band segment to the CW segment, perform a complete tune up of the transmitter.
Do NOT adjust the LOAD control to reduce power output!!!
Mike W5RKL
www.w5rkl.com
RMC(SW) USN RET
