Author Topic: VHF antenna distance from mast  (Read 286 times)
KJ6TSX
« on: April 20, 2019, 01:35:19 PM »
I have a Hex beam on a 1 1/4 mast at about 35 feet above ground and wanted to hang a "DR. Fong"  J-Pole antenna off the side of the mast at about 30 feet. How far should the antenna be from the mast horizontally?
Thanks
George
K6AER
« Reply #1 on: April 20, 2019, 10:15:48 PM »
About a 1/4 wavelength and you will have a little gain in that direction. There will be a bit of a null on the opposite side. The farther the antenna is mounted from the mast the less interaction there will be.
N8EKT
« Reply #2 on: April 21, 2019, 01:47:16 PM »
1\4 wavelength will give a directional pattern
1\2 wavelength will give a bi-directional pattern
1 wavelenth or more will produce a more omni directional pattern
