Author Topic: Feed Line and Window Pass-Through Recommendations for Apartment HF Station?  (Read 575 times)
KD6DXA
« on: July 13, 2019, 06:27:43 PM »
I am putting together a new apartment-dwelling HF station and could use some recommendations on feed lines and window pass-throughs. Our apartment has fairly modern double-pane windows, and I was thinking about trying the Comet CTC-50M coax window pass-through?
https://www.universal-radio.com/catalog/antsup/2750.html
Does anyone have any experience with these window pass-throughs? If so, will they work well on modern windows that seal fairly tightly? If not, I’m all ears for other feed line and/or pass-through options.
Thanks!
Zachary, KD6DXA
Zachary Fruhling, KD6DXA
https://www.zacharyfruhling.com/
« Reply #1 on: July 14, 2019, 03:31:20 AM »
I used the same type of device, but a different brand, in my house in Germany. I could observe the impedance bump with a TDR but it made no practical difference in SWR. It worked well for me 80 through 10 meters with 100 watts.
My windows and casements were wooden. I would be a little more skeptical if you have aluminum in either.
F8WBD
« Reply #2 on: July 15, 2019, 01:42:06 PM »
I've used the same Comet. Avoid opening and closing the window frequently. In fact, not at all once installed correctly. 100 watts max and  best to keep it even less.
K7FSU
« Reply #3 on: July 27, 2019, 01:34:20 PM »
Used two of the Comets for several years.  Work just fine, and I agree with the install & leave them alone suggestion.  Used 100 watts as well.  No problem.
KD6DXA
« Reply #4 on: August 01, 2019, 08:25:44 PM »
My only concern is that we tend to open and close the windows quite frequently (and with frequency—pardon the pun). And the windows are fairly modern double-pane windows, so it will already be a tight squeeze, even for a pass-through as thin as the Comet pass-through. I'll be raising the antenna in the next couple of weeks. Worst-case I'll just run the coax through the open window when I want to operate, but fingers crossed on the Comet.
Zachary, KD6DXA
N8FVJ
« Reply #5 on: August 02, 2019, 07:52:44 AM »
MFJ makes a wood insert that you cut to size (width) at bottom of window. It has multiple coax connectors.
