Pages: Prev 1 2 [3] 4 5 Next   Go Down
Author Topic: Is Astron still king?  (Read 2294 times)
« Reply #30 on: July 18, 2019, 04:47:41 PM »
So what you guys are appearing to be saying is that MTTR is important, and the Astron (or I guess, any other good linear supply) is likely to have a much lower MTTR than any switcher. that goes along with my feeling - experience has shown that when a switcher fails, there has normally been a chain reaction taking out more than  a few semiconductors. OF course being an 'old fart', I'm much happier with analogue circuitry than switchers...
WA7ARK
« Reply #31 on: July 18, 2019, 05:49:43 PM »
MTTR?
Mike, WA7ARK
« Reply #32 on: July 18, 2019, 05:55:42 PM »
The first picture is with one of the lamps replaced with LED's.  (only one was burned out) this shows the difference between the old incandescent lamp and the LED
 And second pix is with both replaced.
ARRL Missouri Technical Specialist
« Reply #33 on: July 18, 2019, 05:57:17 PM »
MTTR?
Mean Time To Repair.  Or we might say Mean Time Between Failure.
« Reply #34 on: July 19, 2019, 03:35:39 AM »
MTTR is the initialism for mean time to repair. It is the average time it takes to repair something once it has failed or broken.
MTBF is the is the initialism for mean time between failures. This is the average "run" time before a device fails.
The general engineering goal is therefore to maximize MTBF and minimize MTTR as this will result in the greatest availability of the equipment. There are many variations to this goal, however. For example, if the acquisition cost of the equipment is low and the MTBF is high, then the MTTR may not matter - it is considered throw away since the total cost of repair may exceed the replacement cost.
« Last Edit: July 19, 2019, 03:48:13 AM by W9IQ » Logged
WB5UAA
« Reply #35 on: July 19, 2019, 05:21:31 AM »
EXACTLY!
I was a fan of Astron for many years.  Big, heavy, silent, solid, reliable power supplies.  Then one day, that little red rocker on/off switch fell apart.  After some significant googling, I found a replacement.  When I saw the price for another little red rocker switch, I decided it's time to upgrade my power supplies to the more modern "disposable" power supplies of today.  (After all, that's where we are in the "state" of electronics today.)  I practically gave away my three Astrons (couple of 35s and a 20.)  Now I have a *supply* of some MFJ switchers (~$100 each, two NIB on my shelf) and I don't see any noise on the HF radio.  I also have some Alinco switchers with a knob on the front that varies the switching frequency (I've never adjusted them...) if you need to move the noise on the HF radio.  I like the small, lightweight power supplies now.  And they take up much less space in the operating position.  And if anything goes wrong, I take the whole power supply, throw it in my recycle box and replace it with a brand new power supply.  No more trying to *fix* an old, dusty, aging, "going to break again soon," heavy, takes up a lot of space, hard to find parts for power supply.
I was an electronics maintenance guy for many years.  We're becoming obsolete.  (If not already obsolete...)
But then again, to each is own!
KC0MYW
« Reply #36 on: July 19, 2019, 07:51:31 AM »
Not sure what you were able to find, and of course prices and availability of things change over time so that could play a part.
I recently acquired another linear Astron supply (It's a RS-12A and I intend to use it for other-than-radio purposes) and in searching for some new rubber feet for it I was doing some online research to try and find a part number. I ended up getting https://www.mouser.com/ProductDetail/3M-Electronic-Specialty/SJ-5023-BLACK?qs=sGAEpiMZZMs6x5FGDTpfsAVq%252BWJOTwqsfembSiiSRXE%3D and they appear to be correct, but I have not put them on yet.
One of the pages I happened across in my research was: http://www.repeater-builder.com/astron/astron-repair/astron-repair.html
On that page, there is some information regarding some "commonly replaced parts" and a part number for a new rocker switch.
I don't have a need for a new rocker switch at this time, but as I was ordering anyway and that switch is here:
https://www.mouser.com/ProductDetail/Carling-Technologies/LRA211-RS-B-125N?qs=sGAEpiMZZMsqIr59i2oRcjvnT%252BmcDpesWNFWAnxYOSs%3D
I decided to get a couple to have on hand in case I ever do need one, they are only $1.01 each at the current time.
Now, I do also have a couple of switching supplies (not Astrons) and they are definitely smaller, lighter, and (I haven't personally measured) supposed to be more energy efficient. I like both linear and switching supplies for different reasons and different purposes, it all depends on the goals and requirements.
VA3VF
« Reply #37 on: July 19, 2019, 08:05:54 AM »
I was in the consumer electronics business in the late 80's early 90's. In the early 90's, a decision was made that equipment up to a certain $ value would simply be replaced with a new one, no servicing. A bunch of technicians were let go as a result.
Then, early in the 21st century, at another place, all the electronics guys became computer guys. The justification: everything is a computer these days.
« Last Edit: July 19, 2019, 08:23:32 AM by VA3VF » Logged
W9WD
« Reply #38 on: July 19, 2019, 08:10:19 AM »
I think I should have asked if Astron is still "King of the linear amps".
I like the idea of brute force in power supplies.
Simple and powerful.
Greg
On the continental divide in the wilds of New Mexico.
« Reply #39 on: July 19, 2019, 08:11:32 AM »
What often drives these decisions is the cost of labor for the repair. The parts costs are typically quite low.
So as hobbyists, we can often ignore the labor cost or even justify it for the sake of learning or self satisfaction. This another reason for the popularity of the Astron line - they are easy to service and it is trivial to find the appropriate parts.
« Reply #40 on: July 19, 2019, 08:35:24 AM »
The hardest part of building your own high power linear power supply is finding the high current transformer.
N9AOP
« Reply #41 on: July 19, 2019, 09:50:09 AM »
The Astron 'brick' supplies are nice for the home station and seem to last forever but for portable use I like the Samlex.
Does anyone remember the 100amp 12V supply made by TenTec?  It was about the size of a college dorm room refrigerator and you needed a fork lift to move it.
Art
W5DXP
« Reply #42 on: July 19, 2019, 11:52:13 AM »
There is probably a power output value where the switching power supply wins overall. To me it seems to be around 500 watts.
My antenna says, "What makes me happy is when the tuner is adjusted for maximum available current through my radiation resistance!" 73, Cecil, w5dxp.com
« Reply #43 on: July 19, 2019, 12:17:30 PM »
I think that is a good observation, Cecil.
« Reply #44 on: July 19, 2019, 01:14:41 PM »
Pages: Prev 1 2 [3] 4 5 Next   Go Up
