Author Topic: kenwood ts-850s/at 13 pin  (Read 192 times)
KB5VAI
« on: July 16, 2019, 09:37:47 PM »
Hi.  i am having a recurring issue with my Kenwood ts-850s/at.
trying to get digital up on it, have a usb signalink device.  It's cable plugs into
the 13 pin port with no issues.  However, aftermarket user built cables do not
plug in at all.  i don't want to force it in.  one ebay seller found cutting the
connector helped, alas not with mine.  i would like to take out the usb signalink
device.  is this typical for this radio?
K4JJL
« Reply #1 on: July 17, 2019, 05:14:54 AM »
There are 2 different sizes of pins made for DIN connectors.  I had the same problem when I made a video cable for an old Commodore 64.  The pins were too large for the jack on the computer.
Check the pin size in your plug and compare to the jack.
KB5VAI
« Reply #2 on: July 19, 2019, 02:59:13 PM »
thanks. will have to pull radio out to look.
