Author Topic: WSJT-X - Hamlib error - changed antenna  (Read 299 times)
WB6DNL
« on: July 20, 2019, 11:23:01 AM »
I’ve been working 20- and 40-meters FT8 with an OCF dipole.  Today, I tried 15-meters with a Chameleon EMCOMM-II antenna (it’s a “portable” wire antenna with a matching unit that requires an external tuner). I got the following WSJT-X error message: “Hamlib error: Communication bus error while setting current frequency.”  It is possible that the antenna is causing the problem (RFI that I’ve not notice using other modes?)?
Dave -- WB6DNL
« Reply #1 on: July 20, 2019, 12:00:21 PM »
Certainly possible.   Hook up to your dummy load on the exact frequency and exact same power level to confirm that it is RFI causing the problem.. If you don't have a dummy load, I would highly recommend getting/building one, they are always useful. If confirmed then take steps to get antenna further away, use ferrites, change length of coax, etc to try to mitigate problem.
ARRL Missouri Technical Specialist
WB6DNL
« Reply #2 on: July 20, 2019, 02:22:23 PM »
James (K0UA) — Exploration reveals that the problem seems to be confined to15-meters (e.g., made contacts on 17-meters w/o a problem using the EMCOMM-II).  Also, I’ve noticed that, at my location, there’s incredible noise across 15-meters, regardless of which antenna I use.  Bottom line, I can live with the problem for now.
Regarding ferrite beads, I have three Mix 31 beads on the EMCOMM-II coax at the antenna tuner.  Is this where I should have them placed?  Also, I assume it wouldn’t hurt to add more?
I don’t have a dummy load, but know that I should. When I want to feel like I do, I go up on 10-meters and “work” SSB.
Dave -- WB6DNL
VA3VF
« Reply #3 on: July 20, 2019, 03:37:19 PM »
Three beads may not be enough. Suggest you install an MFJ-915, it has 50 beads, and costs $35. It did wonders for my station.
« Reply #4 on: July 20, 2019, 03:53:56 PM »
Dave -- WB6DNL
I don't know the size of your ferrites, but if you can put more than one turn of coax thru them you gain by doing it.  If you put 2 turns thru it is 4 times a single turn.
WB6DNL
« Reply #5 on: July 20, 2019, 06:35:56 PM »
I don't think I have any large ferrite beads, but I have more of them.  I'll give all a try.  Thanks to both of you.
Dave -- WB6DNL
