Author Topic: 1kd5  (Read 1306 times)
KE7ASO
« on: February 06, 2008, 03:12:39 PM »
Need someone with good knowledge of henry 1kd5. To review difference between as-built and schematic. There is an error in the values of the components in the grid metering circuit. Or I have a different schematic from the two amps that I have. It appears that vr2 should be 5k ohms without the 220 ohm resistor across that pot. If any one has a schematic that is different than the one on bama I would appreciate hearing from you.Vr1 and Vr2 on the bama and the old manual I have are listed as 1k pots. Any help with this will get this project back on track.
Thanks Ke7aso, alias King Davis.
