Author Topic: Icom Pro3 to FL2100z = Need ALC connection info'  (Read 1478 times)
M0BSZ
« on: April 08, 2008, 11:37:21 PM »
Hi all,
I have a Icom Pro 3 and Yaesu FL2100z.
Relay buffer is an Ameritron ARB 704.
My question is:
What is the best policy regarding the ALC connection between the Tx and Amp.
1 - Is it needed.
2 - Is the Pro 3 and 2100z ALC connections compatible, or will I burn the shack down/damage radio, if I connect these !!
Any help appreciated.
Thanks
Alan
M0BSZ
K6AER
« Reply #1 on: April 09, 2008, 10:52:13 AM »
If you connect the ALC from the FL-2100 you will find the ALC output is very aggressive with up to -9 VDC. This will shut of the transmitter in the Pro for about 4 seconds while the internal electrolytic discharges. If you want to use the ALC output you need to build a resistance divider out of a 5K pot.
Now for the good news. The power output of the Pro-III is very good with no overshoot upon key up and during use. Set the power out so as not to overdrive the little FL-2100 and you will be fine.
My Pro-III is very stable on the maximum output power settings. If I set it to 45 watts out there are no spikes in power output.
